s5 t2 manifold options
Old Jul 12, 2007 | 10:34 PM
initial D is REAL!'s Avatar
I got a s5 turbo to upgrade for my s4 engine, but just realized that the manifold has a different flange. Which one of those ebay brands sells s5 t2 stock replacement manifolds?
ANyone got a oem manifold?
Old Jul 12, 2007 | 10:54 PM
FC3S.USD's Avatar
Where is my Life ?
none
Old Jul 12, 2007 | 10:58 PM
waaaaaaaa. DOH! I had a s4 turbo and a ebay s4 t2 manifold. I bought a s5 t2 turbo as an upgrade, and I noticed the flange is different after. Im such a newb. Any got a used oem one???
Old Jul 13, 2007 | 01:30 AM
freemanrx7's Avatar
^Hold On
I'm a newb to this turbo stuff! I'm doing the same thing to my new s4 engine. From what I understand Yes you will need a stock s5 manifold. You will also need the s5 coolant and oil lines. While you have the s5 turbo in hand have it ported. The s4 heat sheild will not fit 100% correct. So if you want it covered get a stock s5 heat sheilds or a turbo blanket.
Old Jul 13, 2007 | 01:48 AM
Doh! I need the oil and water lines too? Im getting a headache
Old Jul 13, 2007 | 02:29 AM
RotaryResurrection's Avatar
coolant hard lines are the same. if you have an s4 engine, just put the stock s4 oil lines onto the s5 turbo and you'll be good.
You have to use an s5 stock manifold with an s5 turbo/hotside...there is no aftermarket alternative.
Turblown
Mar 21, 2018 11:19 AM
Mrmatt3465
Interior / Exterior / Audio
Sep 17, 2015 01:28 PM
Joe's_7
Sep 8, 2015 04:44 PM
