NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
day before rotorfest; nasty voltage draw: no cranky
Old Jul 7, 2007 | 09:16 PM
twas the day before rotorfest
car didnt start
she wouldnt turn over
not even a fart.
This is just unreal. I went out this morning, she started right up, after sitting for like a week. Turned the car around so I had the front facing the garage door. I grabbed some tools, checked things out, changed oil, changed wheels (this turned out to be a 4 hour project) one stud snapped on right rear no biggy I still had four, figured i'd change it on Monday. When I went to left rear, 3 snapped. I'm like no f*****g way. Cant ride on just 2, that coulnd't wait till Monday. Good thing I keep all kinds of stuff on hand, I had a few here on the shelf. I went to take the rotor off, and those little phillips screws wouldnt budge. So I said the hell with them, went and got my drill and extractor set and went at it (had them on hand too). When I was all done with everything, figured I'll a little ride, and make sure everything is ok. NO DICE! When to turn the key, nodda. I knew the battery was good, but I checked it any, battery was ok. I had a meter on the battery, and when key set to acc., voltage drop down to 7 volts, turn key and nodda. Took battery out of girlfreinds, which I just bought last month. I know that was good, and still same thing, 7volts showing on acc., and no cranky. I know this should acctually be posted in the FC section, but since this is keeping me from going to rotorfest, I thought maybe I could get some quick help. This has not been my day. I went back over everything I did 3 times over, and found nodda. WHERE does my voltage draw come from all the sudden. Please help, I wanna go, I missed last year. In the mean time I will keep brainstorming here.
Old Jul 7, 2007 | 09:54 PM
Jose Feliciano's Avatar
chosen 1
check your grounds
Old Jul 7, 2007 | 10:30 PM
Silverfc88's Avatar
Do you have an aftermarket stereo with an amp? Thats just wierd to see that much of a drop when you turn the key to ACC. What is the voltage with the battery sitting there with the cables hooked up and nothing turned on?
Old Jul 7, 2007 | 10:35 PM
grounds checked: no amp in car; battery reads 12.58 volts sitting, and i also tried jumping with another vehicle, and same thing, down to seven when turned to acc.
Old Jul 7, 2007 | 10:48 PM
Silverfc88's Avatar
Hmm, maybe pull all under hood fuses and then turn on ACC and see if there is still a draw?
I'm trying to remember what else you can run with the key on ACC? Like what can you turn on or what sees power?
Old Jul 8, 2007 | 12:36 AM
amp's Avatar
amp
old yella
same here..
played musical chairs with three sets of twin turbos today..
of course snapping studs along the way..
Old Jul 8, 2007 | 05:48 AM
2FAST7S's Avatar
Originally Posted by amp
same here..
At least you have options, I'm stuck with my smokey ones!!!
What kind of tester do you have? If you can do a load test that might help.
If you havent done so yet, start pulling fuses and relays...good luck
The1Sun
Sep 18, 2015 07:13 PM
Donald Hampton
Sep 17, 2015 03:13 PM
The1Sun
Sep 15, 2015 04:45 PM
RxglassJAw
NE RX-7 Forum
Sep 10, 2015 07:35 PM
