Apexi Turbo Timer install
Old Mar 31, 2002 | 03:53 PM
does anyone know where to plug in the wiring harness for an apexi turbo timer?
Old Mar 31, 2002 | 04:42 PM
aztecwell's Avatar
The harness plugs in under the steering wheel. If you remove the black plastic covers (one has the heater vent and the other goes around the steering column), you will see it. It is right behind a blue, flat, three inch plug. I had to disconnect a lot of wires before I got the harness situated correctly. Here's a tip... my ignition harness was a biotch to get apart... I had to use a small screwdriver to depress the tab so I could pull the plug out. Everything was pretty tight in there, but after some re-arranging it all fit together nicely.
As far as the other 3 wires... the gray goes to the parking brake switch, the white to the ECU for the O2 sensor and the black to the ECU ground. If you don't use the white for the A/F ratio, you will still have to take the black to ground somewhere on the chassis for the timer to work. Good luck.
Old May 23, 2002 | 11:36 PM
MDoMe7's Avatar
flipaholic
hey...where can i tap in for the parking brake line?
is the 02 sensor wire black? the diagram that came with the apexi turbo timer pointed out a black wire but i'm not so sure if that's right
Old May 24, 2002 | 12:04 AM
MDoMe7's Avatar
flipaholic
help ^
Old May 24, 2002 | 07:52 AM
MDoMe7's Avatar
flipaholic
anyone have a diagram of the eco wiring?
Old May 24, 2002 | 08:15 AM
2 hott's Avatar
Don't remeber the color off hand. If you have the manual and the ECU in the correct positions it is easy to figure out. If that is what you did go with that.
Old May 24, 2002 | 09:03 AM
SaltyDog12's Avatar
I believe in the paper work with the timer there is a pamplet thing that shows which wire off of our ECU is the 02 sensor.... If it's like mine, it's a black and white diagram that's kinda fuzzy.
And don't feel bad if you can't get the "Auto" part of the timer to work right. I just have mine set up on a certain length of time. No one i've talkd to (including the people at Apex'i) could tell me how to set it up to monitor itself and shut down when levels are acceptable.
Old May 24, 2002 | 09:11 AM
MDoMe7's Avatar
flipaholic
thanks..i did splice into the black 02 wire ( i just wasn't sure if it was a ground wire or in fact the O2 wire)
I opened up the center console where the brake lever was...i couldn't pinpoint where the brake signal wire was...i just saw the crank (or maybe i just didn't look hard enough?) and there are a bunch of wires for the different buttons on the console...
can someone tell me which one and what color is of the brake line?
Old May 27, 2002 | 05:37 PM
2 hott's Avatar
I think it is a light green or grey. Check by the brake pivot point it will be near that.
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
