Megasquirt cas signal
Old Jun 25, 2007 | 06:30 PM
brent clement's Avatar
Fabricator and builder
cas signal
Can't seem to get the ms to pick up the signal from the cas. I've tried adjusting the pots and checked the wiriing, still nothing. Can someone please give me a detailed description of how you adjust the pots? I've searched and can't seem to find it. I'm running the v3 on an s5 t2 with s4 coils and cas.
Brent
Old Jun 25, 2007 | 09:33 PM
renns's Avatar
Try starting here:
http://www.megamanual.com/ms2/vradjust.htm
Old Jun 25, 2007 | 10:11 PM
Thanks, not sure how I didn't find that before.LOL.
Old Jun 26, 2007 | 09:20 AM
muythaibxr's Avatar
MegaSquirt Mod
Are you running missing tooth with teeth cut out, or second trigger using the G signal?
Ken
Old Jun 26, 2007 | 06:51 PM
Did it both ways, turns out we just needed to play with the pots. Just to be sure what settings should I be running with no missing teeth for both leading and trailing coils? It's picking up the cas now, just not firing the coils. Haven't had a chance to play with it yet though. Thanks again,
Brent
Devon Murray
Sep 26, 2015 08:15 AM
