Microtech No trailing spark but got rpm! Help!
Old Jun 20, 2007 | 03:21 PM
Sindregutt's Avatar
Hi!
Ive been driving my rx7 for a while now without really knowing if the ignition is correct so i started fiddeling with it..
Its a 13bRE with s4 CAS and jspec s4 pullies.. LT8..
I got no trailing spark (checked with a plug hooked to the wire while running the engine etc) i got RPM signal to my stock gauge but when i rev it past 4-5k i loose the signal but it comes back when im under 4-5k rpm..
My wires and plugs are all new.. the trailing coil has worked befor!
Also, are you using the leading or trailing for checking for correct ign?
Old Jun 20, 2007 | 09:19 PM
pistones's Avatar
you should be checking timing with leading plug 1. check your CAS wiring connections, that could cause you to have a bad signal. or you might have a bad CAS .and double check your grounds.
Old Jun 21, 2007 | 12:54 PM
Sindregutt's Avatar
I got no errors on the microtech and i got RPM on the microtech all the way.. so the CAS signals are okey ..
rgordon1979
40
Mar 15, 2022 12:04 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
The1Sun
Sep 15, 2015 04:45 PM
j_tso
1st Gen General Discussion
Sep 11, 2015 09:33 PM
The1Sun
Sep 7, 2015 10:21 PM
