Exhaust leak, I need help guys
Old Mar 29, 2002 | 11:53 PM
N1XRR's Avatar
Well, let me start off by saying I took my downpipe off of my car this weekend and got the leak welded. Dunno what caused it, but I did fix one problem.
When it was off I discovered my O2 sensor was bad, need to replace that.
Here's the kicker, I have a gasket leaking in the manifold area. Definetly behind the turbo. So here's my question, what needs to be taken off to take off the turbo? Upper and lower intake manifold I'm assuming...but is that it? Anyone?
Old Apr 1, 2002 | 10:03 AM
N1XRR's Avatar
Bump
Can anyone tell me what I need to take off?
Old Apr 1, 2002 | 10:14 AM
Samps's Avatar
I don't have a turbo so I don't know. But a Haynes manual will tell you how. If you don't feel like buying the manual just go to the parts store and look it up and takes some notes then go home and wrench away. The service manual at www.fc3s.org probably has the info you need also.
Old Apr 2, 2002 | 07:37 PM
vaughnc's Avatar
knowledge junkie
only buy the steel downpipes. Heavier but there more reliable.
Old Apr 2, 2002 | 07:48 PM
RETed's Avatar
Intake manifolds stay in place.&nbsp The exhaust needs to be "loosened" and the turbo hoses all need to be removed.
-Ted
Tylerx7fb
39
May 27, 2019 12:45 PM
Kyo
Apr 13, 2019 09:24 AM
Clacor
Aug 14, 2015 09:17 AM
