Wheel spacer question
Old Jun 11, 2007 | 01:41 AM
KaiFD3S's Avatar
SINFUL7
would it be safe to run a 5mm spacer and not change the wheel stud, I tried it and it looks like it grips the bolt preety good but dont know if it is safe or not..
Thanks in advance
Kai
Old Jun 11, 2007 | 08:01 AM
Xeros's Avatar
I'm sorry wha?
Dont most spacers come with their own Studs?
Old Jun 11, 2007 | 08:24 AM
ptrhahn's Avatar
No.
I just ran a set of spacers with my track wheels for the first time a few weeks ago, and ended up hosing up two of the studs... there just isn't enough thread room on there. I'm going to have longer ones put in.
Old Jun 11, 2007 | 03:17 PM
7syawedis's Avatar
better safe than sorry just get some slightly longer studs
Old Jun 11, 2007 | 03:44 PM
aznpoopy's Avatar
strike up the paean
5mm is nothing
before you redo twenty wheel studs get an open ended lug nut and check to see if the nut is fully screwed onto the stud. if yes, you're good to go.
very few, and if they do it will probably be on the thicker spacers...certainly not a 5mm spacer.
Old Jun 11, 2007 | 11:07 PM
misterstyx69's Avatar
Retired Moderator, RIP
I don't Know if this Helps,but the Other day,the subject of Wheel Spacers came up.If the Spacer will allow you to Put the Wheel nut on SIX turns,it is Deemed "safe".Now.before I get Bombarded by Criticism,"safe" in What perspective,I don't really Know.(as in for Racing or just everyday Street action.).Frankly though,any Wheel nut that is on my car and goes Six Turns before tight,Is Enough for me...OH!,and yes!..,There are Two types of spacers.One that looks like a ,that just slips over the studs, between the wheel and the rotor,And the Second Version is one that Has holes For the Studs.you Tighten down the Spacer. The Spacer has "alternative studs" that you use for the Wheel.You then Place the wheel on those Studs and tighten it Down...Hope that helps.
Old Jan 2, 2008 | 10:06 PM
su_maverick's Avatar
Back in the 7 life again
interested in this as well. Has anybody successfully run a 5mm spacer or a 10mm? Thinking about getting them but dont want to sacrifice safety to do so.
Old Jan 3, 2008 | 10:32 AM
owen is fat's Avatar
I sure wouldnt try it without longer wheelstuds, theyre so easy to change in front on an FC and not that hard out back either and theyre not even that much money.
Old Jan 3, 2008 | 11:08 AM
TRISPEEDFD3S's Avatar
FEED me
Would you have to get the new ones pressed in? If yes, then I see why folks wouldn't want to do it. Too much work...haha
Old Jan 3, 2008 | 01:24 PM
Black91n/a's Avatar
You don't need a press or anything, a hammer works just fine for getting the studs in and out, but it's a good idea to take the hubs off so that you're not potentially damaging the bearings.
diabolical1
30
Jan 30, 2016 05:50 AM
