Sponsored by: CARiD
S5 to S4 intake swap = idle problems HELP!
Old Jun 3, 2007 | 03:44 PM
88RXVERT's Avatar
OK newbie here,
I did the S5 to S4 upper and lower intake swap, used the S4 throttle body, all new fuel and vacuum hoses, new O-rings & grommets for the injectors , I got rid of most of the emissions controls and their related sensors, solenoids and vacuum spider, I kept the air pump and AVC as I am using them to control the six ports and the VDI temporarily, anyway it starts up like a champ, but if you feather the accelerator pedal it revs slowly, but if you step on it hard it bogs then revs high, if you step on it normal it stalls, it you turn on the AC it stalls, if you engage the clutch it stalls, I have tried to adjust the idle everyway I can.
Also, right now I have the large port above the VDI port capped, I know it goes to the air sensor, but with the S5 setup where does it go from there, I already have both outlets from the air funnel in use, one for the metering oil bleeds and the other to the BAC.
Any suggestions?
Kyo
Apr 13, 2019 09:24 AM
Azevedo
26
Mar 1, 2019 09:19 PM
alphawolff
Nov 17, 2015 05:57 PM
rkhanso
Aug 13, 2015 11:40 AM
