The horror... I'm cutting my springs!!
Old Mar 27, 2002 | 11:38 PM
Bambam7's Avatar
I came, I saw, I boosted.
Yep....well, if done in moderation- it's fine!
I've done a number of searches, and most people who have done it, and those who race as well agree that it's perfectly fine if you only knock off a coil or so... it's a great cosmetic and handling upgrade!
It's where jokers take out 3 or 4 coils, because they could never buy a spring so low (and radically unsafe) that things get dangerous.
So- I'm going to cut mine. I know the RB springs are only 60 a set. and I'll get them sometime, but this is a free, temporary improvement
Also- my car has a nasty rake- like a 79 trans am...!
I want to lower the front by no more than 3/4"- 1", and the rear by about 1.5 or so... (no more) to even it out.
My question- with the car on level ground, can I just measure 1.5" in from the end of the spring, mark it, cut it, and will it equate to exactly a 1.5" drop? Or will it be less or more because of a different spring rate with the 1" gone?
I don't want to go any lower than 1.5 inches in the back- I'll get WAY to much neg camber..
Anyone recomend heights? I only want a mild drop- I don't want the car boucing around like a Honda!
Also- cut from the bottom or top of the spring in the rear?
I know the front's are progressive... what is recomended to cut from, top or bottom?
Even if I can't do the front, I'd still like to cut the back 3/4" or so to even the car out...
Thanks!
Old Mar 27, 2002 | 11:47 PM
chaos7's Avatar
oops didnt read carefully enough
Old Mar 28, 2002 | 12:11 AM
Taranis's Avatar
Awhile back someone (I think RETed) mentioned that lowering the car more than 1" would throw off the camber quite a bit and you'd need camber plates to correct it. I'm no suspension guru.. Would this be a bad problem even if you only take off an inch?
- JB
Old Mar 28, 2002 | 12:22 AM
RETed's Avatar
My suggestion is...
Remove tire and jack the hub up from underneath with a hydraulic jack.&nbsp This will give you an idea of how much of the spring to cut down once you have that corner "loaded".
I've been in an FC with cut down ST springs, and it felt fine.&nbsp Like you said, moderation is the key.
Taranis is also right - you have to watch out in the rear as you end up with too much negative camber dropping anything past 1".&nbsp Better have some money for a rear camber adjust rod to take out all that camber, or else you end up with squealing tires on hard acceleration (reduced tire contact patch) and irregular tire wear (eats the insides of the rear tires real quick).
-Ted
Old Mar 28, 2002 | 02:22 AM
chatch's Avatar
Ted is right about the camber, when I cut mine on my GTU the rear wheels looked like they were riding on the inner lip of the tire, and the ride sucked, gets way to "floaty". Ill never cut springs again. Granted I did have my 16" Konigs almost in the wheel well.
Old Mar 28, 2002 | 02:36 AM
MasteRX's Avatar
More Than Meets the Eye
I have stock springs, but they are old and worn so my car sits lower than stock I think. But anyway, my rear camber is bad and rides on the inner lip of the tire, in fact my tires right now are down to the threads on the inner lip but are fine on the outer edge (I need to get new ones quick).
Old Mar 28, 2002 | 03:03 AM
speederx7@yahoo.com's Avatar
I have an 86 and its on stock sus. It looks like the rears have a lot of negitive camber but when I did a wheel alignment it was almost exact. Realize we have sports cars so theres going to diffrences between hondas and us. My instructor has a 91 M5 and it looks neg cambered
really bad but its at stock specs.
Old Mar 28, 2002 | 07:14 AM
tmak26b's Avatar
I will sell you my Eibach springs :P
Old Mar 28, 2002 | 07:37 AM
SureShot's Avatar
Seduced by the DARK SIDE
I am a serious cheapskate. I plan cut about .8" next week.
Old Mar 28, 2002 | 09:57 AM
Silkworm's Avatar
Has been.. hangin' around
If you're a math major, you could probably figure out how much to cut to give you 1.5" of drop. Me, I'm not. So all I can tell you, use a CUT OFF WHEEL, not a torch to cut the spring, and go half a coil at a time. Yeah, it's a PITA, but unless someone else who's done it can tell you how much to cut to get the drop you want, that's the best way to do it.
And definitely not, cutting 1.5" of spring is not going to give you 1.5" of drop.
PaulC
Old Mar 28, 2002 | 10:05 AM
Bambam7's Avatar
OK- that's what I figured.
I have noticed a lot of 86's riding a lot lower.. especially in tha back.. I noticed the neg camber. (worn springs) My old 88 was worn too.
OK- 1" max in the back.
1/2 inch in the front.
Does any one know... cut from the top or the bottom of the springs??
Old Mar 28, 2002 | 10:11 AM
Jahoo88's Avatar
Does anyone know the stock spring rates? # of coils? Total length of the springs?
Old Mar 28, 2002 | 11:24 AM
takerwolf's Avatar
Is there some stiffer springs you can get that don't lower the car?
Old Mar 28, 2002 | 11:45 AM
Bambam7's Avatar
Why?
Lowering the car lower the center of gravity, even that little bit is considerable because of the wieght of the car.
The 1-2" drop improves the handling just as much as the stiffer rates.
If your springs are worn, and your car looks low, don't worry, aftermarket springs won't drop it any more... they'll be about the same- and be stiffer.
Old Mar 28, 2002 | 06:01 PM
RETed's Avatar
1988 Mazda factory service manual...
front - coil number - left - soft 6.05/hard 5.51
right - soft 5.83/hard 5.31
free length - left - soft 14.4"/hard 13.3"
right - soft 14.0"/hard 12.9"
rear - coil number - soft 10.81/hard 10.79
free length - soft 14.45"/hard 14.0"
Jack Yamaguchi quotes 2.0kg/mm front, 2.0kg/mm rear.
I've seen old GReddy catalogs that quote 2.0kg/mm front, 1.8kg/mm rear.
Times 55.88 to convert kg/mm to #/in.
2.0kg/mm = ~112#/in.
1.8kg/mm = ~101#/in.
-Ted
Old Mar 28, 2002 | 09:41 PM
SpeedRacer's Avatar
Formula Mazda Driver
I think this slightly differs depending on model and year, but my 90 GTU had 120lbs. front and 90lbs rear. I'm not POSTIVE on that that though. If you do cut your springs, make sure you cut down your bump rubber. Lowering your car without raising the spring rate will make your car bottom on the spring rubbers much more easily. That is very bad if your are corning hard and you hit the bump rubbers. It can cause snap oversteer VERY easily.
Old Mar 28, 2002 | 11:29 PM
takerwolf's Avatar
I would just like stiffer springs but don't want it any lower than it is now (at least not the amount of drop aftermarket kits do). Any idea how to tell if they are sagging? (87 Turbo 55,000 original miles, 3rd owner, only owned since June so no clue what it use to sit like)?
What about full coilovers?
Old Jun 29, 2003 | 03:18 PM
Castrol86GXL's Avatar
no one ever says to cut from the top or bottom of the springs but my guess is the top
Old Jun 29, 2003 | 04:26 PM
yearrgh's Avatar
Must...scrub...parts...
Does anyone know the compressed length of the springs while the car is sitting? It shouldn't be too hard to calculate if you know the free and compressed length of a normal spring, and the compressed length you want after cutting. It wouldn't be exact if the spring rates are progressive, but i'd think it would be close enough. Anyone agree with me?
BTW Castrol, what the hell was that twisted thing thats you're avatar before Godzilla got to it?
Old Jun 29, 2003 | 04:42 PM
Elysian's Avatar
Bimmer *****
do me a favor and get those changed like today, i had to donate my 87 TII to the junk yard because of that i don't want to see it happen to another FC, those r way too cool of a car to send to the junk yard
Old Jun 29, 2003 | 06:25 PM
its a nissan skyline gtr 34
http://skylinesdownunder.com/skyline...ry/deadr34.jpg
Old Jun 29, 2003 | 06:26 PM
why what does it do???
Old Jun 29, 2003 | 06:48 PM
Ezekiel702's Avatar
Get what changed? What is that bad? Sorry I couldnt find what you were talking about.
Old Jun 29, 2003 | 08:06 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
this is coming back from the dead
Old Jun 29, 2003 | 08:07 PM
Elysian's Avatar
Bimmer *****
what happened to me was i lost traction at about 40 mph when i downshifted to 3rd to get up to bout 45 or 50 in the rain... my tires lit up instantly and i lost control, spinning thru the median and hitting a bus head on. so please, don't let ur tires get too bald lol
