Microtech wiring lT10 unit
Old May 29, 2007 | 07:09 AM
13bturbofc's Avatar
mmm doritos
Question wiring lT10 unit
i have just started to wire up my LT10 and i had a few questions about it..first one is i wired up the coils with the correct wires on the diagram but i was wondering where the other stock wires are supposed to go? do you just leave them dissconnected or plug them back in?
Old May 29, 2007 | 07:32 AM
hondahater's Avatar
spending too much money..
you should be wiring these in pre connector so if you ever have to take them out all you have to do is unplug the connector and go. I learned this the hard way
Old May 29, 2007 | 09:11 AM
13bturbofc's Avatar
mmm doritos
i solderd the microtech harness wires in after the coil but before the plug on the coil side so the plug is still hanging dissconnected with the unused wires still attached...is that wrong?
Old May 30, 2007 | 07:04 AM
hondahater's Avatar
Well it just kind of sucks because if you want to change coils or replace your ecu with something else etc... etc... you have to cut and rewire. I did this on my lt8 install but will be doing it differant on my lt10 install.
Old May 30, 2007 | 07:12 AM
13bturbofc's Avatar
mmm doritos
yeah i see what your saying..... what about the unused wires?
Old May 30, 2007 | 10:09 PM
hondahater's Avatar
basically you just connect it to the harness to the coils and the connector at the bottom just sits there and does nothing.
_Tones_
May 25, 2021 05:37 AM
astrum
Sep 7, 2015 11:41 PM
The1Sun
Sep 7, 2015 10:21 PM
