Microtech Wiring in LT8S...
Old May 26, 2007 | 04:50 PM
Dorifto_PG's Avatar
Wiring in LT8S...
I am trying to wire in my LT8S into my FC with a Painless wiring kit. The guy I bought the LT8S from didn't give me any diagrams or software that I can use to find a Microtech wiring diagram, so i was wondering if anyone had some uploaded.
Its a real easy job, I just want to do it right the first time, instead of guessing and crap like that.
Thanks guys.
Old May 26, 2007 | 05:00 PM
Dorifto_PG's Avatar
Oh yeah forgot to mention, the Microtech is already wired up to my engine. I just took everything out of one car and put it into my car. Before I amke any assumptions I need to know what wiring i need to combine from my chassis (Painless) to my Microtech (LT8S). THe painless harness is full wired to my chassis, and the fuel pump works, power, aux, ignition, etc.
DO i just wire the Switched Ignition, and constant power to 2 wires on the Microtech (i'm not gonna make any color assumptions) and then ground the Microtech, and everything should be fine? Is there any more "combining" that i need to do of the LT8S and the wired chassis?
Old May 26, 2007 | 06:41 PM
13bturbofc's Avatar
mmm doritos
wiring diagrams can be found at microtechefi.com
Old May 26, 2007 | 11:23 PM
Dorifto_PG's Avatar
Hey, I'll double check i did everything right, I basically just sat there and looked... things are pretty obvious. Hardest parts were just converting **** from when the car had an SR20DET in it. Starter and alternator are totally different.
Old May 27, 2007 | 05:28 PM
jm93rx7's Avatar
Committee Member #3
http://www.microtech-efi.com/downloads/17.pdf
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
