Does Oil Brand Matter?
Old May 24, 2007 | 05:43 PM
Dak's Avatar
Dak
Information Regurgitator
Does motor oil brand really matter?As far as comparing conventional oils.Not conventional vs. synthetic and using the major brands Castrol, Mobil, Havaline,Valvaline,etc. Highest API ratied stuff. Not the no name SF rated convience store stuff. I've always been a diehard Castrol GTX user but with prices going up some others are cheaper. Mobil Clean 5000 is 46 cents cheaper. I've always heard don't switch brands but does it matter? Can a person run whatever is cheapest at each oil change with no ill effects? Your thoughts? Thanks.
Old May 25, 2007 | 01:52 PM
ikari899's Avatar
engineer wanabe
honestly? its all just about the exact same at this point. but i will never stop using castrol GTX in rotaries.
Old May 25, 2007 | 11:37 PM
Evil Aviator's Avatar
Rotorhead
Besides the SAE and API ratings, there are many other factors like detergents, purity, film strength, stability, volatility, etc. You can research many of these factors on the internet by surfing various oil vendor websites (especially synthetic oil vendors), although any information will obviously be slanted toward their product. Most RX-7 owners like Castrol GTX because it holds up very well to the rotary engine's shearing tendencies, and it is pretty good on sludge control. I am not aware of any leading brands of conventional oil that would hurt your engine.
Old May 30, 2007 | 05:22 PM
1QWIK7's Avatar
White chicks > *
Its all the same really.
I just switch up oils because i think my turbos are going out.
So far mobil 1 helped a bit.
Old May 31, 2007 | 08:21 AM
fastrotaries's Avatar
W. TX chirpin Monkey
I've pretty muched used only 3. Mobil !, Royal Purplpe, and AMSOIL. When I can get it, Amsoil has my vote.
Old May 31, 2007 | 09:02 AM
hondahater's Avatar
spending too much money..
when the mop is gone and you are premixing is it better to use synthetic oils? I know this is a newb question but I've often wondered this. Since those that premix don't have to worry about if the oil is good or bad at burning then we are free to use whatever oil best suits the internals of the engine. So this being said is synthetic better on bearings, rotors, turbos etc... I seem to remember hearing something about synthetic is very bad for the carbon seal inside of turbos, is this correct?
Old May 31, 2007 | 09:18 AM
Twinnos's Avatar
935 Wicked Dragger East
can i run valvoline synthetic oil and be ok in my FD?
Old May 31, 2007 | 09:22 AM
hondahater's Avatar
you really want something that burns and burns clean if you are using the stock metering oil pump. If you don't premix then really some of the best oil to use is castrol gtx. Most of the synthetic oils out there are made not to burn witch is not good for the rotary unless you are premixing.
