turbo problems need help
Old May 18, 2007 | 03:07 PM
mazdaspeed274's Avatar
Ok hears my problem i have a 93 rx7 with a garrett gt35r setup on it.. The car was running great for awhile but then started to act up. I started to loose all power and now have no boost. The boost gauge works and says i have boost but the car does not move when you hit the gas. Ive had problems with these turbos before and have had to send them back to garrett for new seals.. Any insite on what this might be?
Old May 18, 2007 | 05:09 PM
CarbonR1's Avatar
Where is your boost gauge taking pressure readings from? What kind of boost gauge?
What do you mean your car is not moving? Please be more specific.
Kevin
Old May 18, 2007 | 06:06 PM
dhahlen's Avatar
FD Under Construction =P
Also, if you're building boost and the car isn't going anywhere it could be a number of things.
Timing could cause that, as well as a number of other things.
More details please.
Old May 19, 2007 | 02:19 PM
nikko379's Avatar
Microtech is fastest
disconect batt
press brake 3min
reconect batt
drive car/ if it boost better you have a static
problem [too much tape somewhere] sterio ,turbo timer, some acc. not oem on your car.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
