Sponsored by: CARiD
What are the Highest injector flow rates Mazda made ????
Old May 17, 2007 | 05:13 PM
rx413b's Avatar
General Rotary Tech Support HELPPPPPPPPPPPPPPPPPPPPPP
I have search all over the world wide web ( WWW ) to find out what are the flow rates of Mazda rotary injectors. From the normally aspirated to the turbo and up to there triple rotary engines.
If you have correct information can you please quote it in this thread.
Please quote the year and model the injectors where fitted to vehicle , Injector style , part number , High Impedance or Low Impedance injector , flow rate @ fuel pressure setting , number# CCM or number# LBS/HR@PSI.
Any information would be helpful . even links to known websites
http://www.fuelinjectorclinic.com/ca...ctors_cats.htm
http://www.robietherobot.com/storm/f...ectorguide.htm
http://injector.com/injectorselection.php
http://www.rceng.com/technical.htm
http://www.witchhunter.com/injectorcalc1.php4
http://www.megamanual.com/v22manual/rotary.htm
http://en.wikipedia.org/wiki/Mazda_Wankel_engine
http://www.fd3s.net/injector_upgrade.html
thanks guys
Old May 17, 2007 | 05:31 PM
crispeed's Avatar
'Tuna'
Supposedly one of the generations of the 12A turbo injectors were the highest flowing top feeds and the secondary FD side feed injectors also.
13b GSL-SE........680cc(some say 720cc)
12A turbo blue top......720cc
12A turbo green top......800cc(some say 880cc) nippondenso 195500-0830
FD secondary..............850cc
84-85 13B NT low square center 680cc orange 195500-0900
86-87 13B NT low square center 460cc red 195500-1350
86-87 13B T low square center 550cc tan 195500-1370
88 13B NT high square offset 460cc purple 195500-1350
88 13b T high square offset 550cc purple 195500-1370
89-91 13B NT high oval center 460cc red 195500-2010
89-91 13B T high oval center 550cc purple 195500-2020
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
