Sponsored by: CARiD
Transmission won't separate from the block
Old May 15, 2007 | 07:17 PM
RISEN's Avatar
I'm trying to pull out my transmission to replace the clutch but the transmission will not separate from the block. It is clearly separated from the studs and it can free spin clockwise or counter clockwise but it seems as if it's stuck to the flywheel? I tried to separate them apart with a crowbar, but no luck! I did a search but nothing helpful has come up.
Any help will be appreciated. Thanks.
Old May 15, 2007 | 07:49 PM
Mahjik's Avatar
Mr. Links
The easiest thing to do (if you can't figure out the wedge collar) is to remove the pressure plate bolts through the inspection plate (just keep turning it until you get them all).
Old May 15, 2007 | 07:58 PM
RISEN's Avatar
Thanks
P.S. I used to work on Hondas so this is a different experience.
Old May 15, 2007 | 08:13 PM
Mahjik's Avatar
Mr. Links
No problem. It's not uncommon to have a problem the first time separating a pull type clutch. When you learn how to separate the wedge collar, it makes the job very simple.
Old May 15, 2007 | 08:22 PM
Is this on an FD?
Old May 16, 2007 | 12:27 PM
RISEN's Avatar
FD yes. I couldn't figure out the wedge collar. So I removed the 6 bolts. Thanks.
Old Jun 14, 2007 | 01:53 PM
-xlr8planet-'s Avatar
I has an emblem
There was a video on youtube on how to do it
firzen
Sep 15, 2015 12:04 PM
Enzo1944
Sep 6, 2015 08:57 AM
