free motor and fly wheel in northern VA.
OK here is the deal. My motor has 22.500miles but has little oil leak.
i just ordered reman engine because i had little oil leak. engine runs strong and apex seal is in great condition but it leak oil.
For those who has blown apex seal than my motor might be good choice.
So long story short I have to return my core soon and if anyone is interested i'll trade you my engine for your long as it is in returnable condition. It must be 93-95 fd engine.
I also have new fly wheel came with reman motor, bring yours and trade for new unit.
WHY AM I DOING THIS? because i have to return it anyway so for me it doesn't matter it has good apex seal or not long as it is in returnable condition.
Where are you leaking oil ... Turbo or Motor(Oil Seals)??? I have an FD motor that had a factory reman and lost the coolant seal. I am thinking rebuild and streetport. I might be interested depending on the problem.
oil is leaking from rear rotor housing and cast housing meets. probably a seal but not common on fds.
One word of caution, some companies require that the cores have good housings that they can reuse. So if you get a core with bad housings, you might not get all your core refund back. I know this is how Pettit works anyway.
