Microtech fan relay
Old May 7, 2007 | 09:42 PM
cpnneeda's Avatar
RAWR!!!!!!!!
fan relay
Have a LT8 in a TII. We put in a FAL fan, and ended up having to put in a relay to get it to work right. My question is, we know which wires to use for the power, ground, signal, which wire are you all using for ignition on. We used the diagram given in the book for the fuel pump relay, and pink is the designated color for that. Would that wire work for the fan relay, or does that wire pulse to much? Thanks for the info, and if you need more info let me know.
squirrels
Sep 1, 2024 09:52 AM
