Bouncing idle - Couldn't find exactly what I was looking for with search
Old May 7, 2007 | 01:25 PM
pauli311's Avatar
Anyways, car just started doing this the other day ...
It seems to have lost a bit of power and not boosting as hard as it used to.
Runs a little rich
and now when warm it will idle at 750 for a bit then drop to 300-400 ish and bounce between.
Also to be noted, if I have my interior fan on at speed 3 or 4, the engine will idle higher.. so when its drawing more current the engine just wants to idle higher... it has always done this.
I don't know if it is connected but maybe....
my car also makes that Moo'ing sound... no idea if that is related either
It should be noted that this car is an automatic.
Thanks,
Pauli
Old May 7, 2007 | 01:41 PM
ATLGT's Avatar
Mine does the idle loop and it has a blown water seal so you may want to start there. Other than that, check you injectors. Could be getting too much or too little fuel. Post your engine specs. Miles/rebuild stuff like that.
Old May 7, 2007 | 03:19 PM
pauli311's Avatar
64k miles on engine...
apexi intakes
HKS downpipe
RB exhaust.. most reliability mods
stock ECU
Old May 7, 2007 | 09:38 PM
technomentor's Avatar
Brings Order to Chaos
Check to see if the vacumm line popped off the boost sensor on the firewall...
Old May 7, 2007 | 10:09 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
you may have leak in your IM gasket. Get some carb cleaner and spray around that area, and while you are at it spay around all the vacuum hoses. If your car dies or changes in idle you found your culprit.
Old May 8, 2007 | 12:04 AM
Fatfree rx7's Avatar
Issues?
I would spray around the LIM and check for lines by the firewall. Also, that "mooo" sound is caused if you removed your air pump.
Old May 8, 2007 | 09:43 AM
mono4lamar's Avatar
In the burnout box...
Guys, a vac leak would raise the idle.
It sounds like the problem I'm currently going about. I would replace the injectors with some flow matched ones. If you need a set I have a bunch of them. The price is 120 shipping and paypal fees included. I'm sending out my 850's and 1600's when i get time to tear them out.
Old May 8, 2007 | 02:18 PM
pauli311's Avatar
Update:
Upon investigating further, it seems the vaccuum is bouncing somewhere between 17-13 at the same time the rpms are going between 300-400-750.
If I go WOT for a bit and let it de-rev it smooths out for a bit then goes back to the same pattern.
I definately had WOT in 3rd on the auto and it wasnt boosting any higher than 4..
the mooing sound is coming from the tube that feeds the intake from the airpump.... but its the apexi intake... is it still supposed to sound like that?
Old May 9, 2007 | 12:13 AM
Narfle's Avatar
Rx7 Wagon
sounds like low compression
Old May 9, 2007 | 08:55 AM
pauli311's Avatar
Well I took a couple videos of the car and you can kind of hear the rough idle but I also took a vid of the boost gauge and you can see the needle bouncing as well
I'll have em on later today but thanks to those who are giving this some thought
Old May 9, 2007 | 09:38 AM
mono4lamar's Avatar
If hes pulling 17in vacuum at 750 I wouldn't call that call that low compression. Great vacuum is 18 at idle. I would first check the tps adjustment. If you cannot get it within spec the sensor is corroded inside. Other than that the only other think i think it could be is injectors...
85TIIDEVIL
Aug 25, 2015 12:09 AM
BLK 93
Aug 19, 2015 03:47 AM
LMBTG
Aug 15, 2015 01:43 PM
