Why does my stock downpipe glow red???
Old Mar 25, 2002 | 11:40 AM
RX-8's Avatar
My car is at Mazduh, and they can't seem to fix it. I just had a new motor put in, but now the car doesn't have the power it should. It accelerates ok at half throttle, but at full throttle it accelates slower. Or boggs down and hesitates, but only at full throttle. The only clue I have to what may be wrong is that the downpipe glows red. Any suggestions????
Old Mar 25, 2002 | 11:42 AM
ttpowerd's Avatar
HARRRRRRRRR
downpipe glows when there is exesive heat. When you run your car really hard for extended periods of time the turbos will create a ton of heat causing the dp to glow.
Your problem sounds like a fuel management issue.
Old Mar 25, 2002 | 12:17 PM
RX-8's Avatar
thanks for the response ttpowered. I think there going to replace a fuel sensor underneath the intake. Does that sond right??
Old Mar 25, 2002 | 12:21 PM
Toadman's Avatar
Nomad Mod
Check your main cat converter for clogging as well. Excess back-pressure will hold back heat dissipation.
Old Mar 25, 2002 | 12:25 PM
Bucrx7's Avatar
How much mileage on the precat? Sounds like it's clogged.
Old Mar 25, 2002 | 12:29 PM
ttpowerd's Avatar
HARRRRRRRRR
do you have a downpipe or the stock pre cat...
a) precat is clogged
b) stock cat is clogged
c) fuel management issue
I thought you had a dp.....
Old Mar 25, 2002 | 12:36 PM
RX-8's Avatar
It's the stock pre-cat and I have 52,000 miles on it.
Old Mar 25, 2002 | 12:43 PM
mightyslash's Avatar
Will Work for Ferrari
Everyone thought you had an aftermarket downpipe....
Old Mar 25, 2002 | 12:47 PM
ttpowerd's Avatar
HARRRRRRRRR
I would replace the precat with a dp, then see where that leaves you. Then I would check into a hi flow cat, cat back, ecu, intake oops sorry, hehe
Seriously though I would look at that too.
Old Mar 25, 2002 | 12:51 PM
RX-8's Avatar
sorry for the confussion. So a clogged precat could effect acceleration at full throttle?
Old Mar 25, 2002 | 12:56 PM
rynberg's Avatar
Like the others said, either your pre-cat or main-cat is clogged (could be the reason for the blown engine) or you are running very lean for some reason (could also be the reason for the blown engine).
Old Mar 25, 2002 | 01:16 PM
RX-8's Avatar
I had the fuel filter changed along with the new engine. So i don't think its fuel, not unless it's a sensor. Maybe I'll order a downpipe and try that. I never knew that a clogged pre-cat would cause me to accelerate faster at half throttle then full!
Old Mar 25, 2002 | 02:08 PM
mr_jonboy's Avatar
Don't really know about accelerating faster but the clogged precat will give more backpressure off the turbo probably allowing more torque down low. This clog will then give poor flow up top and aide in lower topend HP. Anyone can correct me if I am wrong.
I would just get a DP. If that doesn't happen to be the problem. Oh well. You still just gained HP, quicker spool, and enhanced sound.
Old Mar 25, 2002 | 02:40 PM
Salguod's Avatar
You are correct Sir.
Microtech
Aug 23, 2015 11:04 AM
