Help:new Rx7 Owner
Old May 1, 2007 | 11:18 AM
mattchan6668's Avatar
Wink Help:new Rx7 Owner
I brought a rx7 97year in korea and i want to know what type of engine oil is the best with my 7 (In korea now the temperture around (6-30)
i want to change all of the belts and tensioners what those parts i can buy from internet?
Old May 1, 2007 | 11:31 AM
edwin-82/rx7's Avatar
7-itis
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
FAQ! Owner's manual will also tell you what weight oil to run for what temperature.
Old May 1, 2007 | 11:42 AM
rynberg's Avatar
Cutting some slack for the language barrier, from the FAQ thread:
33) What oil should I use?
First, there is the synthetic vs. dino debate. There is no consensus to this issue. Some experts recommend synthetic, others insist on regular oil. Early on, synthetic oil did not burn well in the combustion chamber - but this is not an issue with modern synthetics. What matters is that it gets changed on schedule – every 3000 miles or less. Some owners choose to change at 1500 miles to offset the fact that the oil cooler(s) is not drained during an oil change. The proper weight is 20w-50 in warm climates and 10w-30 in any place that gets cold in winter.
Most FD owners run from 10w-30 to a 20w-50. It depends on whether the car will experience use in cold winter conditions, or extended track conditions. In either case, the thicker 20w-50 is usually ok since fuel dilution will occur and thin the oil. Very thin oils (0w-40) used in some newer cars are not a good choice.
I do not know the part availability in Korea, but I'm sure there are any number of dealers in Japan that could ship to you.
MADDSLOW's Avatar
17 second FD
lol I was JUST about to post "Where's rynberg when you need him?"
Th0m4s
Feb 26, 2019 02:04 AM
Jutta_J
Mar 25, 2017 11:24 PM
