Cwest Front bumper how did you mount your's?
Old Apr 25, 2007 | 06:58 AM
LasVegasGS's Avatar
Hey guys I have a C-west front bumper how did you go about mounting your's did you use the hardware from your OEM bumper or did you only use the 2 holes that are on the sides of the C west one. Pics would help alot Thank you
Old Apr 25, 2007 | 07:42 AM
bryant's Avatar
bryant
mine has brackets run from the oil coolers on both sides to the kit.
Old Apr 25, 2007 | 07:55 AM
skotx's Avatar
Registered Abuser
The previous owner of my car had a CWest installed and I've swapped it off and on several times. He did not use any bracing from the original bumper. It was mounted using the tabs across the top that attach to the core support and the topmost spot on the fender (don't know why they didn't drill for the other two). The bottom of the fender well liner was also screwed into the front end. Whoever installed it also added angle iron from the tow hook-looking things to the front lip.
-Scott
Old Apr 25, 2007 | 08:09 AM
bryant's Avatar
bryant
dirty from the 11 hour haul thru the blizard
Old Apr 26, 2007 | 06:07 AM
LasVegasGS's Avatar
-Scott
Ya its odd on the sides it only has one threaded hole and one that goes to the fender. then the 4 that go to the core support do you have any pic's how how your's look.
Old Apr 29, 2007 | 08:41 AM
LasVegasGS's Avatar
Are there any how to install this bumper threads?
rexone
The Bad & Fugly Businesses
Aug 23, 2015 06:24 AM
