Microtech T-2 No Spark
Old Apr 21, 2007 | 07:20 PM
jm93rx7's Avatar
Committee Member #3
T-2 No Spark
Im not getting any spark on T2. I checked with 2 other trailing coils that i know are good and still nothing. I checked the wiring from the ECU to the coil and its fine. The car will start and idle. I pull the plug wires at the coils and im getting spark on L1, L2, T1 and nothing on T2. Anyone have any idea whats going on.
Old Apr 21, 2007 | 09:58 PM
turbodrx7's Avatar
PURIST
Have you changed your plug wire? If you did, its gotta be a coil problems, i dont think the wiring is for seperate parts of the coil, i remember mine had 2 wires, but i dont think 1 was for each T side.
Old Apr 21, 2007 | 11:06 PM
jm93rx7's Avatar
Committee Member #3
I can try a new plug wire for T2 but im not getting spark at the coil or at the plug. does that make a diffrence?
Old Apr 22, 2007 | 09:42 AM
turbodrx7's Avatar
PURIST
How are you testing spark at the coil? Im stupid and messed it up. Are you sure you have a working coil?
Old Apr 22, 2007 | 09:49 AM
jm93rx7's Avatar
Committee Member #3
when the car is idling im getting spark on L1,L2,T1 but not T2. Im checking it by pulling the spark plug wire from the coil.
Old Apr 22, 2007 | 09:51 AM
turbodrx7's Avatar
PURIST
Have you tested your ignitor?
Old Apr 22, 2007 | 09:56 AM
jm93rx7's Avatar
Committee Member #3
I tried another coil that i know is good and still same issue
Old Apr 22, 2007 | 09:59 AM
turbodrx7's Avatar
PURIST
So it may not be the coil. Did you test your ignitor?
Old Apr 22, 2007 | 10:01 AM
jm93rx7's Avatar
Committee Member #3
how do i test the ignitor?
Old Apr 22, 2007 | 10:06 AM
turbodrx7's Avatar
PURIST
What microtech do you have?
Old Apr 22, 2007 | 10:11 AM
jm93rx7's Avatar
Committee Member #3
Lt8s
Old Apr 22, 2007 | 10:15 AM
turbodrx7's Avatar
PURIST
if i were you, i would jsut swap out the ignitor for another. They are a dime a dozen.
Old Apr 25, 2007 | 05:04 PM
jm93rx7's Avatar
Committee Member #3
update.
swapped trailing coil for another one that im sure is good. Nothing
pulled the CAS to see if the dimple was aligned with the nipple on the casing. Nothing
Swapped CAS for one that i know works. Nothing
Changed plug wires. Nothing
Any other suggestions?
Video coming soon.
Old Apr 25, 2007 | 05:06 PM
jm93rx7's Avatar
Committee Member #3
http://www.youtube.com/watch?v=J9I-GZLGKOg
Old Apr 25, 2007 | 07:55 PM
jm93rx7's Avatar
Committee Member #3
anyone?
Old Apr 26, 2007 | 12:21 AM
tocix's Avatar
Same **** diff smell
Im in the same boat no spark on Trailing 2
standard motor and ECU
all i heard was a backfire 1minute into warming up after changing a battery and now cant start and no spark on T2
have i rooted my ECU?
cheers fellas
Old Apr 26, 2007 | 04:34 AM
tocix's Avatar
After a tow start still no start
spark on L1 L2 T1 but not T2
charged battery
65,000klm good comp
Factory setup
also changed the coil to another and still the same issue no spark on T2
what can it be?
is there anything else i can try to start this puppy
other than set it on fire 1 !
cheers all
Old Apr 26, 2007 | 05:25 AM
jm93rx7's Avatar
Committee Member #3
i had someone tell me that it was most likely an internal problem with the ECU and i was going to have to send it back to microtech to have it tested and repaired
Old Apr 26, 2007 | 05:44 AM
tocix's Avatar
charged battery
65,000klm good comp
Factory setup
what can it be?
cheers all
Its only a standard ECU
Old Apr 26, 2007 | 01:43 PM
turbodrx7's Avatar
PURIST
Well than get another stock ecu. If its a stock ecu, we cant really help you here. It could be anything from your wire harness being old and cracked, to your ecu failing.
Old Apr 26, 2007 | 09:17 PM
tocix's Avatar
Cheers
got it started and also found a vaccum leak wich was preventing start up
once startup is active there is no probs with idling just lack of power
it seems that its running but does not run that well due to no spark on T2?
bad ECU is my best geuss
cheers all
Old May 19, 2007 | 02:58 PM
jm93rx7's Avatar
Committee Member #3
got a reply from microtech.
"Someone has changed the spark trigger to negative.It should be set on +MAZ when using the 13B coilpacks"
ECU should be here thursday.
Old May 21, 2007 | 03:15 AM
BeNO's Avatar
Exclamation
I kind of having the same problem !!!
The car was working perfectlly fine. Store it for about two months then the L1 and T2 do not work !!! I didn't change anything as far as computer programming.
I have checked the connection its fine. the coils are brand new, duble checked them and they are good.
checked the ECU it is working no errors and the connection on the MT seems to be working !!..
Don't know what to do.????
how long did it take to send it to Microtech ?? and get it back ??
Thanks guys.
Old May 21, 2007 | 05:21 AM
jm93rx7's Avatar
Committee Member #3
7 days travel time
about 12 days of them having it ( depends on there woark load )
7 days return travel time
Shipping from FL was about 85 dollars
Old May 22, 2007 | 01:06 AM
BeNO's Avatar
Sooo.. total was 26 days !!! Damn.. that Alot.
