How Much boost I am supposed to have with these mods???
Old Mar 23, 2002 | 01:53 PM
serge1's Avatar
Greetings all,
Ok, I have (or will have) the following mods on my car:
-Intake
-Efini Y pipe
-Cat Back (G-reddy GT)
-Down pipe
-M2 polished intake pipe.
My question is: How much boost in Kg/cm2 I am supposed to do with that???
.70 Kg/cm2 ??? .80Kg/cm2 ????
Thanks all
Serge
Old Mar 23, 2002 | 02:00 PM
GsrSol's Avatar
Z06 powered FD
Without an ECU I would run no more then 0.5
.70 sounds safe
.80 u prob need some fuel system upgrade...
Old Mar 23, 2002 | 03:39 PM
Donovan's Avatar
Hi sir
Well with those mods you SHOULD have only stock boost. The car is going to try to keep the boost at stock levels untill you get an ecu or boost controller. you may get some spiking but the stock cat's back pressure should keep it under controll. With intake, DP, and CB, your next mod will be an ECU of some kind or a new motor.
cristoDathird
28
May 30, 2019 08:47 PM
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
TerryD
Aug 23, 2015 07:40 AM
