90 Lincoln TownCar rims
Old Apr 16, 2007 | 01:51 AM
RoninRX7's Avatar
Im looking at getting another set of rims for the FC vert for autocross, and I found that the lincoln towncar from 90-96 or so had a rim thats nearly identical to the stock vert BBS rims. Heres a pic of one,
It says the bolt patern is 5-4.25", which is the same as the mustang, and the FC i believe, It looks identical to the BBS, and even a 15 X 6.5, and it even has a center cap that is nearly identical. What would i have to do to make these work if the offset is incorrect? The FC is +40 i believe, but i cant find a spec for these, though it should be the same as the mustang. thanks
RoninRX7
Old Apr 16, 2007 | 01:55 AM
spacedog's Avatar
our 2nd gen bolt pattern is 5x4.5"/114.3mm
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
