Can somebody explain in detail how the coolant system works on our car??
Old Mar 22, 2002 | 07:50 PM
Axe's Avatar
Axe
I for one would like a diagram of the coolant system and a list of the most likely perps for leakage so I can check em out.
Old Mar 22, 2002 | 08:25 PM
rynberg's Avatar
This might help somewhat:
http://home.istar.ca/~dvandit/rx7stuff.shtml
Old Mar 23, 2002 | 03:35 AM
maxcooper's Avatar
WWFSMD
Most automotive cooling systems are about the same in their basic operation. Here's how they work:
Car gets hot, pressure builds up in the cooling system. When the pressure gets higher than the radiator cap (AST cap on stock FD) spring, some coolant flows out the tube to the overflow tank.
When the car cools down, some vacuum is created in the cooling system. The radiator cap has another little passage in it that opens under any vacuum condition, so coolant is sucked back into the motor from the overflow tank as it cools down.
Take a look at your radiator cap. It opens to let coolant out of the engine when the pressure overcomes the big spring on there. The coolant flows out of the engine between the rubber seal and the seat inside the filler neck. The second rubber seal that is right under the cap makes sure that the water flows out the overflow tube instead of just coming out around the edge of the cap.
In the middle of the radiator cap, there is a metal button that is about the size of a penny. Carefully pull the button out to see how it opens under vacuum. You can see that the button pulls out easily, and this means that it opens under any vacuum to pull some coolant back into the engine from the overflow tank. You can also imagine why any hole in the overflow tube makes your coolant run low in the engine -- coolant will come out under pressure, but with the hole you'll only suck air back into the engine as it cools.
-Max
Old Mar 24, 2002 | 08:23 PM
rx7speed811's Avatar
Accepting Donations.
is the overflow tank supposed to have a vacuum seal? is the place where the coolant flows out from it just a hole, or is it more of a one-way valve?
Old Mar 25, 2002 | 01:13 AM
maxcooper's Avatar
WWFSMD
The overflow tank should not be sealed, and the tube inside it should go to the bottom, so that fluid is picked up when the engine starts sucking the coolant back into the engine. The overflow tank is like a drink with a straw in it.
-Max
elpartso_robb
Aug 29, 2015 08:45 AM
