carb, fuel, fuel pump problem? car doesnt run and no fuel
Old Apr 9, 2007 | 10:59 PM
chedda_j's Avatar
My car started to progressivly get worse in the last couple days. Starting with weak acceleration, then to sputters, then to hard starts, then to nothing. I tryed a few things and nothing worked. The larger hose on the carb is pissing out fuel like no other so i dont think its the pump. The small hose, im not sure if its a return line, but no fuel is coming out of that one at all. The carb wont shoot any fuel into the intake at all. I tryed to do it while cranking and if you hit the throddle no fuel comes out of the little injector thingers in primaries. No spray no nothing. I get one or two dropps when i let off the throddle but thats it. SO whats my problem? carb?
Old Apr 9, 2007 | 11:12 PM
misterstyx69's Avatar
Retired Moderator, RIP
either the jets are clogged in the carb or your needle is clogged at the Float In the carb.Try Tapping the Carb around the Float area..if you Know you are Getting Fuel to the Carb,and NOT out of the carb,then it is Likely that the problem Lies Within it.
Old Apr 9, 2007 | 11:15 PM
chedda_j's Avatar
yeah im swapping carbs tomorow and seeing if that does anything. Btw, anyone have an 8 spline starter they want to sell me?
Old Apr 10, 2007 | 12:20 AM
trochoid's Avatar
Old Fart Young at Heart
There are also screen filters around the banjo bolts and if the carb's never been touched, there are screens at the needle/seats. Since you're not getting fuel in either bowl, pull the banjo bolts and check before swapping.
Old Apr 10, 2007 | 01:02 AM
cdrad51's Avatar
Lorem ipsum dolor sit ame
Actually he didn't say anything about the bowls, and nobody asked him either.
So, are the bowls half full like they're supposed to or empty?
Old Apr 10, 2007 | 11:59 AM
chedda_j's Avatar
empty
Old Apr 12, 2007 | 12:38 AM
cdrad51's Avatar
OK so did you clean the screen filters or swapped the carbs?
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
Marty RE
Aug 29, 2015 07:51 AM
ashleymiche
Aug 14, 2015 12:59 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
