Megasquirt Wide band O2 questions.
Old Apr 3, 2007 | 01:26 AM
quasar's Avatar
I'm in rotary heaven!
I want to use the wide band O2 sparkandfuel.com is selling but i'm not sure if i need to get the LC-1 Wideband Controller. Can I just get the Replacement Bosch LSU4.2 5-wire, wide-band O2 sensor? What do i need for a successful install?
Old Apr 3, 2007 | 09:21 AM
muythaibxr's Avatar
MegaSquirt Mod
You need a controller... The MS won't directly control a wideband sensor.
The controller controls the sensor, and then outputs a 0-5v signal that the MS can use to determine AFR/Lambda.
Old Apr 4, 2007 | 01:39 PM
quasar's Avatar
Ok, thank you for clearing that up for me.
Coochas
44
Nov 5, 2019 11:08 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
manoflego
19
Sep 30, 2015 05:19 AM
