Radiator Problem!!!!Please HELP!!!
Old Mar 21, 2002 | 04:04 AM
erevos's Avatar
Unhappy Radiator Problem!!!!Please HELP!!!
Greetings from Greece.
I am an owner of a fc3s turbo convertible '91.
I recently crashed it and after the repair the following radiator problem appeared:
The radiator fluid dissapears every 200-300 km!There is no visible leakage and the radiator tank seems ok.Of course i have not disassembled the radiator,but it seems ok.Does anyone know how to fix this problem?PLEASE HELP!!!!
Old Mar 21, 2002 | 04:21 AM
MasteRX's Avatar
More Than Meets the Eye
Sometimes an unexplainable coolant loss can be traced to a bad seal in the engine causing coolant to get into the combustion chamber. The engine then burns this off. What you can do is smell your exhaust fumes to see if it smells like coolant, or better yet, see if it tastes like coolant, if you know what coolant tastes like. Coolant burns as white smoke. So if you are getting a bunch of white smoke, that could be it.
Old Mar 21, 2002 | 09:05 AM
DCmina's Avatar
I thought coolant could kill you if you swallow it.
Old Mar 21, 2002 | 09:15 AM
The Ace's Avatar
Greek Power
Sent you e-mail reply. Check it and get back to me
vmerino
Sep 5, 2015 11:26 AM
