Power FC Uploading the latest unchanged Apexi PFC map
Old Mar 27, 2007 | 05:29 PM
gracer7-rx7's Avatar
needs more track time
Exclamation Uploading the latest unchanged Apexi PFC map
I bought a brand new Power FC from FDNewbie recently. I made a backup of Apexi's stock Power FC map before I reloaded my map for my motor.
I figured that someone might want or need the regular unmolested/unchanged Power FC map as it left from the Apexi factory so I'm uploading here.
Cheers.
File Type: zip
Old Mar 27, 2007 | 05:33 PM
here is a version with the fan settings lowered to 86, 88, 92 with no other changes.
File Type: zip
Old Mar 27, 2007 | 11:18 PM
cewrx7r1's Avatar
Eye In The Sky
That map is the base mod map that has been around since about 2000.
Nothing new.
Old Mar 28, 2007 | 02:47 AM
S8nana's Avatar
thanks mate i'm about to get a POWER FC for my FD... just a quick question does the powerfc have temperature(water temp) output - I have a APEXI EL water temp guage(1st generation)...and don't have the temperature sender unit....?? or know of where to get the sender unit from(or one from a another manufacturer that works)...
cheers.
Old Mar 28, 2007 | 09:15 AM
cewrx7r1's Avatar
Eye In The Sky
The PFC does not have a water temp output. You will have to do what we all have done, install the sender unit for your after market water temp gauge.
Old Mar 28, 2007 | 10:32 AM
Nothing new.
Didn't know that. I had heard the map had been updated over time.
Old Mar 31, 2007 | 06:35 PM
existanzrx7's Avatar
Just Boosting
Dem i cant open it what program do you need to open this file? What program did your computer opened it with?
Old Mar 31, 2007 | 09:13 PM
rynberg's Avatar
You have to have a datalogit (and the FC-edit software) to open and download it.
Old Mar 31, 2007 | 10:31 PM
VegasFD's Avatar
Wishin I Still Had The FD
You can download the FC-Edit software at the sticky at the top of this forum. Download Veger's software bundle on the 2nd page first, then use the update I have posted at the beginning.
