bose stereo... center chanel
93FD...factory Bose. where can i find the center chanel tweeter(small speaker in the dash) mine is not working and i need a replacemant.
im not having any luck through a dealer so im hoping one of you guys has a used one. or know where to get a new one.
thanks
Drew
thanks
Drew
i dont think the amp would just fail to that one channel, espically it being the lowest powered channel....its possible i guess. thanks for the input, ill try malloy to see if its something i can get new.
Drew
Drew
Yes it would. Each speaker has a separate amp and they are notorios for failing. These guys can help. Here is a link to their site discussing/showing the tweeter amp removal.
http://www.carstereohelp.com/stereor...RX7FTwtAmp.htm
good info...thanks. i do need a new speaker though, i even took it out and tested it, the speaker is junk, plus the cone is torn so it was sounding fuzzy before it crapped. ill have to check the amp, i think your right that it blew the speaker.
thanks guys...
if anyone has a center channel tweeter, send a pm this way!
Drew
thanks guys...
Drew
