Can I fit a 255/50/16 Drag Radial on FD wheels on my FC?
Old Mar 23, 2007 | 02:01 PM
Comitatus's Avatar
Down for the count...
Looking to get a set of Drag Radials for my FC. I will be putting them on FD wheels which are 16x8. My question is, can I fit a 255/50/16 in the Rear of the FC on stock suspension? I have also purchased a set of 25mm spacers to push the wheels out a bit.
The only other option i have for a DR on a 16in tire is the Nitto 555R's which come in a 245/50/16, which i know will fit great with the spacers.
I would rather stick to a bias-ply tire to make it easier on my drivetrain. MT ET Street Radials only come in a 255/50/16.
Old Mar 23, 2007 | 02:07 PM
jacobcartmill's Avatar
just dont care.
yes it will work fine with that 1" spacer.
i used to run the 245/50/16 nitto DR's on my FC back in the day with no spacers (on FD wheels) and it would barely rub the trail arm. so a 255 on an FD wheel with 1" spacers will fit fine.
Old Mar 23, 2007 | 04:07 PM
Comitatus's Avatar
Good to know. I'm a lil worried that it might rub on the fender under heavy squat...
Old Mar 24, 2007 | 06:47 PM
moonless's Avatar
I'd be more worried about the torque load on the end of the lug bolt with the 1" spacer. you can fit a 245 45 16 with a +38 offset with out running a spacer or having rubbing issues
Old Mar 24, 2007 | 09:21 PM
Comitatus's Avatar
Aren't FD wheels a +50 offset? I realize I can run a 245/50/16 tire with no rubbing issues at all...but then it comes down to which tire I want. The MT ET Street Radials only come in a 255/50/16. Its a bias ply tire which helps on the torque load of a drivetrain.
fidelity101
13
Aug 31, 2015 07:47 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
