audio guys: question about resistance (ohms)
Old Mar 21, 2007 | 08:33 PM
turBRO240's Avatar
Certified Rotorhead
well... im farthest thing from a noob in audio realated things..... but there is a subject that i really didnt get too much into
simple question.... scince you get more power in lower ohms, why dont all companies use lower ohms like 2?
do you get a better signal or sound quality with higher ohms? or what?
for example, im heavily into live sound and 90% of amps and speakers are rated at 8 ohms.... why dont they all run in 4 or 2 ohms? what are the pros? what are the cons?
Old Mar 21, 2007 | 08:58 PM
X-JaVeN-X's Avatar
Drive.
I'm pretty sure that the lower the resistance the hotter the amp will run, meaning it needs better cooling and potentially shorter life span...but that's just my theory.
Old Mar 22, 2007 | 01:05 AM
purerx7's Avatar
Registered User
most home audio amps are 8 or 4 ohms though, most car audio amps are 4 ohms and can be wired to a 1ohm and a 2ohm depending on the ohm of the speaker or sub woofer. The higher the ohm the less current the amp will draw as well, im pretty sure the higher the ohm the more clear the signal will be, this is why most home audio speakers are 8 ohm. This is a good read and should answer your question:
http://sound.westhost.com/impedanc.htm
Old Mar 23, 2007 | 12:43 AM
palsor1's Avatar
You guys are right. Remember that current = voltage / resistance. Our cars run at a constant voltage, so if you lower the resistance, the current will go up. The more current, the more heat.
Old Mar 23, 2007 | 01:03 AM
turBRO240's Avatar
Certified Rotorhead
therefore.... rotary = -309248 ohms :P haha
_Tones_
May 25, 2021 05:37 AM
firzen
Sep 15, 2015 12:04 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
Nosferatu
Sep 5, 2015 02:13 PM
