Pressure sensor needed?
Old Mar 19, 2007 | 10:26 PM
dwb87's Avatar
This is my social media.
I am doing a 13BT swap and removed the emissions. I was wondering if I'll need to "tap" into the ACV plate and use the S4 N/A pressure sensor or buy a S4 TII pressure sensor... ?
Old Mar 19, 2007 | 10:38 PM
87 t-66's Avatar
not a drifter
you would use the t2 pressure sensor
Old Mar 19, 2007 | 10:39 PM
7dust's Avatar
Irregular Here
Use the turbo pressure sensor and use the nipple on the UIM.
Old Mar 21, 2007 | 01:58 AM
NZConvertible's Avatar
I'm a boost creep...
Yes, and it has to be a Turbo one.
You have to use the Turbo MAP sensor but you don't necessarily have to tap is into the ACV block-of plate. It's the most correct of several correct options. Teeing into the BOV line is easiest and works okay.
You realize half of nipples on the UIM aren't suitable for the MAP sensor? Telling him you use "the nipple" isn't much help...
befarrer
Microtech
Aug 22, 2015 05:52 PM
20B Forum
Aug 18, 2015 02:46 PM
eddierotary
Aug 16, 2015 04:12 PM
