this fuel cut is driving me mad!!!!
Old Mar 16, 2007 | 12:16 PM
The Last Mahadocon's Avatar
someone please help me lol. its and 88 gxl swaped with an s4 13bt. for someone it wont fing go above 4 grand! the secondaries refuse to come on. the injectors are newly rebuilt. there not leaking. the fuel rail deffinetly has fuel runnning through it. the B.C.S is hooked up. the only thing i can really think of is wiring. Before i go and replace the ecu and the wiring harness, could someone please tell me if there are other sensors that i could have missid that would cause this probablom? i just cant understand why my car is doing this. im about to go "attempt" to read my engine codes with a voltmeter... somehow i dont think im gonna be verry successful with my quest but im gonna give it a try. someone save me lol.
Old Mar 16, 2007 | 12:50 PM
Furb's Avatar
Rotary and Engineering
not an expert,
but it could be the 3800rpm hesitation... use the search
Old Mar 16, 2007 | 01:00 PM
rotarymarine's Avatar
Rebuilding the 7
Are you using anything to prevent the fuel cut? When you are at 4000 rpm...what psi are you boosting? TPS might be out of wack too. Hope that helps.
Curtis
Old Mar 16, 2007 | 02:40 PM
ill just barley spike 7 or 8 lbs at 4g's. i was thinking it could be the boost pressure sensor. im gonna try to find someone in tucson with an fc-t so maby i can swap them out to see if thats what it maybe is. anyone els wanna put in there two cents?
Old Mar 16, 2007 | 06:30 PM
NZConvertible's Avatar
I'm a boost creep...
Read post #15 in this thread and do the checks I suggest.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/n-88-sutters-after-3800-rpm-630329/
Old Mar 16, 2007 | 06:52 PM
J-Rat's Avatar
Alcohol Fueled!
Let me chime in here...
I checked the injectors in his car and they are fine. I statically leak checked them, and I click tested them. This car has me a tad bit perplexed...
The car will go above 3800, but it feels like its firing on one rotor. If you LIGHTLY accelerate above 3800 then it will transition fairly well, which leads me to suspect the boost (pressure?) sensor.
I should have pulled the codes when he was here too, but I forgot..
I think I am just going to have to get silly with the Multi-Meter and try to figure this one out.
Old Mar 16, 2007 | 07:14 PM
TehMonkay's Avatar
Back in the game
Are the injector clips good?
I'd check those then start checking the wiring harness measuring the resistance from the wiring at the injector to the ecu.
Are the right impedance injectors being used? 87/87.5?
Old Mar 16, 2007 | 07:46 PM
J-Rat's Avatar
Alcohol Fueled!
Yes, the clips are fine, and the impedance checks out.
Old Mar 16, 2007 | 08:22 PM
Check the voltages at the MAP sensor by back-probing the connector. Leave it plugged in and unbolt the sensor from the body to get easier access to the wires. With the ignition on there should be 12V on the B/W wire, 5V on the Br/W wire, 2-3V on the Br/R (signal) wire and 0V on the B (ground) wire. Measure the resistance between the ground wire and the engine, it should be close to zero. If all that checks out check the signal voltage at the ECU (pin 2B).
ECU pin-out: https://www.rx7club.com/attachment.p...hmentid=165722
Old Mar 16, 2007 | 10:58 PM
J-Rat's Avatar
Alcohol Fueled!
Yeah, I will be checking that.
Old Mar 18, 2007 | 09:10 PM
lol, thanks j rat. ill be attempting to read the codes and ish. tried once, couldnt figure out what the hell i was doin... its pretty simple to understand when you read it, but when you actually try to figure out what there doing is where i lose them
http://www.teamfc3s.org/info/article...odes/main.html
Queppa
Nov 18, 2024 03:47 AM
astrum
24
Nov 15, 2017 08:44 AM
alphawolff
Nov 17, 2015 05:57 PM
armans
Aug 15, 2015 09:08 PM
