Megasquirt How do you wire the tps?
Old Mar 13, 2007 | 04:42 AM
quasar's Avatar
I'm in rotary heaven!
I know there is a ground and two signal wires. What color wire on the tps to what pin on MS1 V3.0? I'm working with a Series 4 turbo.
Old Mar 13, 2007 | 10:02 AM
Aaron Cake's Avatar
Engine, Not Motor
http://www.megamanual.com . You can find the complete Megasquirt wiring diagrams there for your version.
You can find the 2nd gen wiring diagrams in the FSM here:
https://www.rx7club.com/forum/showthread.php?t=494667
Old Mar 15, 2007 | 04:43 AM
quasar's Avatar
I'm only getting 30% full throttle. is this normal or should i just get a new tps and try it again? My setting are 0 and 85 in the calibrator.
Old Mar 15, 2007 | 08:38 AM
Aaron Cake's Avatar
Engine, Not Motor
No, not normal. Does the reading go from 0-30% as you push the throttle? Even the narrow range TPS will give you 100% after about 1/4 pedal travel.
Old Mar 17, 2007 | 01:25 AM
quasar's Avatar
Yeah, full tps travel like your saying is about just a bit over 1/4 pedal reads 30%. This weekend i'll just get a new tps and see how it pans out. Also i'm experiencing erratic signal behavior from the old tps from the 10% mark to the 30% mark, it just jumps around and around 7% it will drop to 0% and if i press just a tad bit more it will pick up around 10% like it has a dead spot or something.
I just got this car and it's raged out very bad, i dont doubt the last owener did any work to it.
Old Mar 17, 2007 | 09:49 AM
Aaron Cake's Avatar
Engine, Not Motor
If you are in for some fab, grab a generic GM or Ford TPS and use it instead. That way you get a brand new standard TPS that is full range.
toplessFC3Sman
Mar 20, 2018 01:54 PM
ZacMan
Sep 19, 2015 09:20 PM
