What other cars wheels will fit the FD?
Old Mar 8, 2007 | 03:17 AM
GoRacer's Avatar
Speed Mach Go Go Go
I know the 350Z will work but what I really want to find out is Porsche, Bugati, Lamboguini, Astin Martin, Z06, Etc?
For example:
Ferari 202 wheels
19x10
50mm offset
67.1mm hub
5x108mm
I'm not shure if the holes can be drilled out or if the hib is too small or needs a ring. Some OEM wheels are heavy but some like the ZO6 are extemely light.
Old Mar 9, 2007 | 01:01 PM
GoRacer's Avatar
Speed Mach Go Go Go
FD - 67 Bore 5x14.3
RX-8 - 67 Bore (match)
350Z - 66.1 Bore (too small) lug centric
Ferrari - 67 Bore 5x108 (requires lug holes to be drilled out)
Porsche - 71.6 Bore (would require ring) 5x130 is not lug centric.
Mustang - 70.5 Bore (would require ring but is lug centric)
Old Mar 9, 2007 | 01:37 PM
ARD T2's Avatar
Just cross reference your boltpattern with those cars.
You're gonna have to stick to Ford 5x114.3, or Most Japanese vehicles are 5x114.3 or 5x100.
Do your wheel fitments on tirerack to find out various boltpatterns for different vehicles.
Rishie
Old Mar 9, 2007 | 06:29 PM
GoRacer's Avatar
Speed Mach Go Go Go
Well I was looking at some Ferrari wheels in 19x8.5/+52 & 19x10/+58. The front offset should work but even with my M2 toe/trails i'm not shure if the rears would. I could do a spacer but then that would throw off my track wheels. Assuming we get more Buddy Club buyers. The local wheel repair shop said they could drill out the lug holes from 108 to 114.3.
