Actuators and things under IMF
Old Mar 18, 2002 | 10:02 AM
rotarypower101's Avatar
sdrawkcab
Actuators and silenoids under IMF
WITH A SINGLE TURBO DOES all them silenoids
actuators and hoses go away or the majority of them
Old Mar 18, 2002 | 10:29 AM
Sidestick's Avatar
Yes. About half of those solenoids control the stock turbos' sequential function, which is all going to go away, the other half is for emissions.
Old Mar 18, 2002 | 10:30 AM
Bucrx7's Avatar
Everything that has to do with the sequantial system is gone.
Old Mar 18, 2002 | 10:45 AM
sdrawkcab
oh god i might just nut
i got to go away for a minute but i am actually building my own turbo kit with a garrett T04E stainless steel manifold and i need to know what the best wastegate is to use im not porting my motor just 3mm seals and fmic ,fuel pump 1320cc secondaries, jacobs rotary pro pack, i want low end boost big time, no cats,dual stock mufflers or similar ,,no noise
What is the best reliable wastegate. for this purely street car
Old Mar 18, 2002 | 12:52 PM
A-Spec Tuning's Avatar
Registered User
Re: Actuators and silenoids under IMF
when you go single turbo..you dont have to remove all the solenoids...if your running a modded stock ecu the solenoids need to be there unless you put in resistors
ZacMan
Sep 19, 2015 09:20 PM
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
