Simple (But stupid) SS brake line install question
Old Feb 28, 2007 | 03:47 PM
archangelkn's Avatar
Question Simple (But stupid) SS brake line install question
I just purchased a set of Russell SS brake lines, and was curious if there's any tips/tricks I should know before installing. Is it just a straight swap from the stock hoses? and do I need to put any type of sealant on the hoses (read somewhere that plumbing tape would be good to put around the bolt).
Also replacing the calipers and Master Cylinder as soon as I get them. Any tips on these?
Old Feb 28, 2007 | 04:12 PM
Mahjik's Avatar
Mr. Links
Yes, some teflon tape or thread sealant would be recommended on the threads. Other than that, it's just a basic swap.
Old Mar 1, 2007 | 07:55 PM
drift into a curb's Avatar
teflon tape isn't needed. the brake line ends should seal without the need of teflon tape. I would recommend getting some crescent flare nut wrenches though so you don't strip the brake lines when disassembling it. Also, get some PB blaster penetrating liquid.
Old Mar 8, 2007 | 02:17 PM
Pat McGroin's Avatar
Sushi ******!
No teflon tape needed on flared fittings.
+1 on the flare nut wrenches, or else you'll send up stripping.
Frisky Arab
13
Aug 18, 2015 05:30 PM
GrossPolluter
Aug 16, 2015 09:50 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
