Where To Buy K-44 Or Seafoam!
Old Feb 19, 2007 | 08:36 PM
TOOSHORT_88's Avatar
"On the grind"
Exclamation Where To Buy K-44 Or Seafoam!
I need to buy k-44 or sea foam , my vert engine is all locked up! (carbon) Heard that this is used to loosen up carbon by putting it in the intake and letting it do its magic for 2 or 3 days.. any info is very helpful
thks jason
Old Feb 19, 2007 | 10:10 PM
-=DanK=-'s Avatar
Well Im not sure what K-44 is but NAPA sells seafoam.
Old Feb 19, 2007 | 11:30 PM
kettlman's Avatar
THE ONE. THE ONLY!
yeah. just check some storesw. i think gi joes might also have it
Old Feb 20, 2007 | 11:34 AM
"On the grind"
ya i checked b&b, schucks, and they did not have it. I will check napa hopefully they got the stuff
thks
Old Feb 20, 2007 | 02:54 PM
Rotarbeast's Avatar
86 Base
get ready for a reubild
Old Feb 20, 2007 | 05:09 PM
Red_Rabbit86's Avatar
new to the rotary world
something i heard if you let water get suxed into the engine by the intake and just have somebody rev it up to about 6k and pass thro for a few mins it tears away at the carbon. however i dont know if i would be willing to do it. just a thought something you might look in to it.
kapn krunch's Avatar
POWERED BY DINOJUICE
i know baxter auto parats has seafoam and mmo. we have a few stores up north
Old Feb 21, 2007 | 12:23 AM
"On the grind"
I got seafoam today. but heard the k-44 stuff is the best. I dont understand it my vert was perfect running condition 112 both rotors very reliable car. Then i parked it for 4 months and now its fucked!
I havent had the time to see if i can even turn the motor over by turning the 19mm bolt on the front cover below water pump to see if it is locked up .
When i try to turn her over with another vehicle assisting the charge. all i get is to clicks like the battery is dead, then i can hear the starter making very slight grrrrrrrr... noise very slight noise....
Old Feb 21, 2007 | 12:56 AM
ddub's Avatar
i am legendary
Pour in your seafoam (ATF works too by the way) through the spark plug holes and leave it for 2-3 days. Then go and try to turn it over slowly, if it doesn't rotate then repeat prior step and wait another 2-3 days. If it does rotate them turn it over 1/3 of the way and put in more seafoam/ATF and wait 2-3 days. Do this for a full rotation and then try to start it again. Be prepared for a gigantic smoke show.
Then once its running and burns off all the seafoam/ATF in the engine you can do the water treatment. Use a vac line to suck in about a gallon of water while the car is running. You will NEED to be inside the car holding the accelerator to keep it running because it will want to die. This will essentially steam clean the inside of the engine. You can also use seafoam instead of the water when doing this.
Old Feb 21, 2007 | 03:29 PM
stoko's Avatar
I looked all over for some seafoam, and finally found it at AutoZone for $7 a can
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
mulcryant
Sep 9, 2015 05:24 PM
