Question about the temperature of the engine?
Old Mar 16, 2002 | 06:51 AM
ccw998's Avatar
Hi,
I am wondering that what is the normal temperature of the engine? My water temperature gauge shows that it is 90'C under the normal driving. Is it normal??
Old Mar 16, 2002 | 08:47 AM
That's because you live in Canada! LOL
Seriously though it is possible that your thermostat is gutted. I think generally running cold is a good thing as long as you make sure the needle moves at all. See Mazda engineers didn't want owners running to the dealer for every little difference from usual readings so your gauge is not very accurate. It actually has 3-4 stop points depending on the range of temp. your running. This is also because they're cheap asses.
Old Mar 16, 2002 | 11:14 AM
SPOautos's Avatar
Hey, where did my $$$ go?
As long as your in the upper 80's C and up your not to cold.
Later,
STEPHEN
Old Mar 16, 2002 | 05:51 PM
ccw998's Avatar
So, what 's the normal temperature of the engine?
Old Mar 16, 2002 | 06:42 PM
mjw's Avatar
mjw
Mine seems to run in the high 80's right now in southern california, I am sure that # will go up in the summer. In town or stop and go traffic it fluctuates up and down depending on the fans, I have seen it hit 99C.. then the fans kick on and bring it back down to the high 80's again.
Matt
93 SSM
Old Mar 16, 2002 | 06:45 PM
P'cola FD's Avatar
Hamado things my way!
I've don the fan mod to keep it at 180(Ferenheit of course) all the time. With the fans turned off in traffic it can get up to 220.
Old Mar 16, 2002 | 07:04 PM
RecKleSs's Avatar
Adrenaline
Your temp is pretty normal for an FD. Get the fan mod, it's definitely a great mod. As for my temps I hit 78-82 C and this is with a fan mod, and Fluidyne radiator. Also, the temps outside would be around 50F
streetlegal?
Mar 17, 2022 02:46 PM
