Boost Question!
Old Mar 15, 2002 | 11:41 PM
Boost Question!
Hi guys, is it save to have 13 psi on stock tiwns with ecu,downpipe,intake and exhaust?
Old Mar 16, 2002 | 04:00 AM
bump!help!
Old Mar 16, 2002 | 08:54 AM
billyrohm's Avatar
Man who sold his 7
It should be safe as long as you have enough fuel
Old Mar 16, 2002 | 10:12 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Yea your probably ok but if you start spiking then go get A boost controller and ecu.Its cheaper than an engine
Old Mar 16, 2002 | 03:37 PM
Bucrx7's Avatar
Yes it is safe but I wouldn't run 13 psi unless it's cold out. In the summer time I would wait for an upgraded IC because the stock one is inefficient.
Old Mar 16, 2002 | 05:24 PM
RecKleSs's Avatar
Adrenaline
My duty cycle in my FD hits 100% when I hit 13psi, which is extremely bad. To be on the safe side upgrade your fuel system and ic if you plan on consistently running 13psi or higher.
Skeese
65
Mar 28, 2017 03:30 PM
