instructions for rx7fashion intake
Old Mar 15, 2002 | 09:39 AM
streetdreamzny's Avatar
i got the intake today and i took out the factory air box but can't seem to get the new air box to fit? thanks in advance
Old Mar 15, 2002 | 09:44 AM
Johnny's Avatar
OG
There is only one way it fits....and you have to sort of force all those box intake in...The important thing to remember is get it as low as possible...there should be 1-2 screw holes at the bottom to hold it down. If you have a aftermarket rad you might have to clip that flap out
Old Mar 15, 2002 | 09:52 AM
johnny the radiator hose is in the way or i'm just to weak to force it in
Old Mar 15, 2002 | 09:54 AM
Johnny's Avatar
OG
Should be able to push that hose to the side a little bit. Yes it is a really tight fit...get even tighter when you get a large SMIC
Old Mar 15, 2002 | 09:41 PM
Trout's Avatar
When sliding the air box's duct between the rad and frame rail watch for a small lip on the frame that sometimes catches the duct. If so, use a screw driver to pry the duct out a little then it should slide down easier.
Jack
Ernstudet22
Sep 14, 2015 09:19 PM
