South RX-7 Forum Serving Texas, Oklahoma, Arkansas, Louisiana, Mississippi
need help asap!!!!!!!
Old Jan 30, 2007 | 08:42 PM
deliorx7's Avatar
Unhappy need help asap!!!!!!!
hey guys whats up. i was looking for someone in the houston area or surroundings that can help me with my FC. i would really like someone with experience(or at least more then me)then can figure out some glitches in my car. sometimes my car wont start, it keeps turning but will never crank over. when it does turn on it throws out alot of white smoke(does not smell like coolant) smells sort of like oil????, and also sounds like its running on one rotor??? after like 5-10 seconds it sounds normal and revs normally. i noticed it started this as soon as the winter came around. so if you can come and help out, or tell me some advice i would greatly appreciate it. i know no one likes working for free, but if you can help out of courtasy, since im in a tight bond right know.
thanks, delio
Old Jan 30, 2007 | 08:54 PM
SingleTurboRx7's Avatar
VP incharge of drinking
sounds like its time for a rebuild
Old Jan 30, 2007 | 09:12 PM
deliorx7's Avatar
already? man this motor only has like 10,000 miles on the rebuilt. the motor still pulls real strong when im driving it. the car will stop smoking like after 1-2 minutes. it will idle fine at 750. it just has problems turning on sometimes. but i have noticed my car runs hotter(not overheating) then usual on the freeway then normally.
Old Jan 30, 2007 | 10:16 PM
RXJIM's Avatar
The hard starts could be leaking injectors, try a good fuel system cleaner like BG44k. You can also get them professionally cleaned locally.
Old Jan 30, 2007 | 10:27 PM
JWteknix's Avatar
injector orings and seats
Old Jan 31, 2007 | 10:34 AM
Chi-RX7's Avatar
USMC
yep
thats what i told him...because ive driven that car b4 and that cars PULLS very strong...i just think that the o rings in the injectors are bad......and it can be flooding his motor with gas....
Old Jan 31, 2007 | 11:51 AM
ajhehr's Avatar
theres a place on waugh and d'amico called I believe bevarian motor work that will rebuild your injectors for a little over 25 a piece.
here it is.
bavarianmachine.com
the oil smokie thing sounds like the oil seals didnt get replaced in the rebuild???
Old Jan 31, 2007 | 07:06 PM
deliorx7's Avatar
can this cause my car to run hot on the highway(not overheating), but the temp. goes down to normal on city.
