fd to fc brakes
Old Jan 30, 2007 | 02:01 PM
nlsolja123's Avatar
fd to fc brakes
will the fd rear brake system completly bolt up to a fc ,
Im asking because i seen a modded fc with this done and im wondering if this can be done without much modding
Old Jan 30, 2007 | 04:14 PM
gnx7's Avatar
I guess the 1st question is what front brakes are you running? The factory FC brakes (vented rotors/5lug) are a good factory design.
Are you running a full blown race car with upgraded power? Are you seeing limits to the current braking system?
Old Jan 30, 2007 | 05:17 PM
StarScreaM2k1's Avatar
Rotax?! WTF is a Rotax!?
From when i last looked into this there is a good amount of work to be done to get the FD ones to fit. There isnt much of a point to it because the cons outweight the pros. Like GNX7 said are you seeing the limits of the current braking system. The FC braking system is very good from factory compared to other cars. Just get some good rotors, check your calipers (make sure they are in good working order, no pistons seized), get some SS lines, change/flush fluid, get some good brake pads and that should be sufficient.
Old Jan 30, 2007 | 05:58 PM
Black91n/a's Avatar
Corksport has a big rear brake kit, but you probably don't need one.
Old Jan 31, 2007 | 02:41 AM
RETed's Avatar
NO.
-Ted
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
