Power FC How "safe" are the maps on the Forum?
Old Mar 13, 2002 | 06:51 PM
Lost Time's Avatar
Chimera Driver
When I say "safe", I mean reliable. Most of them are coming from forum members. Are these tried and true maps that someone has used and is safe for the car, or is it someone's maps they just threw together because it sounded good.
I understand that every car is different and what works for one car may not work for another car with identical mods. I just want to know if I use one of the maps on here, specifically spyfish's for port, dp, mp, cb, intake,(same setup I'm running) that there is some margin for error and that it isn't on the edge.
Since I don't have a datalogit yet, and don't have access to a dyno and lambda right now, am I better off staying with the base maps, or should I try one of the maps on the forum?
Thanks.
Old Mar 13, 2002 | 08:35 PM
skotx's Avatar
Registered Abuser
Check out my site if you haven't already. You can compare Spyfish's maps to the base maps and see exactly what's different. Then you can make a more informed decision. You'll notice that Spyfish's are almost identical to BaseStock.
Most of the maps available were tuned by professionals or tweaked by knowledgable people. In fact, most of the maps we have were tuned by SR Motorsports. I'm running Tim Benton's maps, which, contrary to Spyfish's, are almost identical to BaseMod. According to the opinion of this board, BaseMod is the safer of the two.
Look at your current settings and determine if it's BaseMod or BaseStock (95% chance it'll be BaseMod if you bought it new). Use it for a little while and monitor EGT (if you have a gauge), O2 voltage (wanna be around 0.82 or higher at WOT), Injector Duty (high 80s is nearing the limit), Boost, and the general sound and feel of the car.
With Tim's maps I've run my car moderately hard on the street and put it on the dyno, and haven't had any problems. From what I've heard, and now personal experience affirms, BaseMod is relatively safe. I have a FMIC, Intake, DP, MP, CB, and run stock boost setting #2.
-Scott
Old Mar 14, 2002 | 03:43 AM
spyfish007's Avatar
Yellow Dragon is no more
Don't use my maps .... start with Chuck's maps!
Old Mar 14, 2002 | 05:31 PM
SPOautos's Avatar
Hey, where did my $$$ go?
If your o2 is decent I'd run the base map that came with your PFC with the boost setting around 12psi untill you have a datalogit and dyno to do it right. I dont know anyone thats blown a motor with a untouched PFC map at 12psi. It should be nice and reliable till you can do things right.
What ever you do dont use a XS map because you wont be able to change your base map like XS did.
Good Luck,
STEPHEN
Old Mar 14, 2002 | 05:34 PM
SPOautos's Avatar
Oh yea, if you had to use a new map I'd prob recomend Chucks maps, he has put a wide band to his maps.
STEPHEN
Old Mar 14, 2002 | 07:56 PM
cewrx7r1's Avatar
Eye In The Sky
They refer to my no posted ones at
https://www.rx7club.com/forum/showth...threadid=61008
Old Mar 14, 2002 | 08:37 PM
Lost Time's Avatar
Chimera Driver
Looking at the list of mods you have, I would expect to run extremely rich with the mods I'm running. And I'll assume you're refering to the maps in the .xls file at the end of the initial post. Also, seeing that you have your datalogit, did you change anything in the Commander-unaccessable maps that would cause a problem for me?
I'm currently running:
Street port
DP, MP, CB
Sequential stock twins
Intake
at .82 bar, I'm seeing about 82% duty cycle on the injectors. o2 is well into the green on the Autometer (for whatever that's worth) and I don't have an EGT.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
1987 T2
11
Apr 1, 2017 11:59 PM
befarrer
Sep 4, 2015 08:26 PM
