how much horsepower increase when removing air conditioner??
Old Mar 11, 2002 | 08:39 PM
kam's Avatar
kam
I was wondering how hard it is to remove the air conditioner and how much horsepower will increase with the removal of it
Old Mar 11, 2002 | 09:33 PM
the_saint's Avatar
It is easy to remove the AC, just takes some time, like 20 minutes. But what kind of belt are you going to run to keep your powersteering?
HP gain? not that much IMO. It saves some weight, but I like cold air when it is hot outside.
thesaint
Old Mar 11, 2002 | 09:34 PM
Nathan Kwok's Avatar
When the air conditioner is turned off, the compressor is just freewheeling so you'll basically gain nothing. The main reason for removal is to increase airflow to the radiator and remove some of the clutter inside the engine bay.
Old Mar 12, 2002 | 08:20 AM
rxrotary2_7's Avatar
i removed mine b/c i am alergic to a/c anyway. clears up some clutter and the condenser is a restriction to the radiator. the belt to use is goodyear # 360k6 about $9 at any auto parts store.
Old Mar 12, 2002 | 08:50 AM
jeremy's Avatar
male stripper
wow, i never heard of someone being alergic to a/c. that sucks man.
Old Mar 12, 2002 | 10:34 AM
yep i like the heat anyways. i HATE being cold.
Old Aug 6, 2002 | 04:03 PM
evot23's Avatar
Classy
Can the air condenser be moved to a more flat position to allow more air to hit the radiator directly. Anyone do this?
Old Aug 6, 2002 | 05:37 PM
jspecracer7's Avatar
1JZ powered
yep. Before I took my AC out, I was planning on putting the ac condenser parallel with the ground, underneath the radiator/intercooler. I've seen it done on a few cars now.
Old Aug 6, 2002 | 08:22 PM
ttb's Avatar
ttb
No Cup Holder Racing
don't do it...the fd is like an oven...it's getting hot in here, so take off all your clothes ok i'm bored
Old Aug 6, 2002 | 08:34 PM
evot23's Avatar
Classy
Man you are bored LOL
I live in hot FL and never use the ac anyway.
Will the tubes bend without breaking or should I remove AC refrigerant and do this?
thanks!!
Old Aug 6, 2002 | 08:59 PM
94touring's Avatar
I have my condenser parallel with the ground beneath my radiator and fmic. I even had enough room to stick a 12" fan on the bottom blowing air up, which helps keep my ac cool. As low as my car is i've never had any problems with rubbing or damage to the fan.
Old Aug 6, 2002 | 09:31 PM
evot23's Avatar
Classy
94touring
Can you email or post or pm me how you did this, any tips or tricks to watch out for?
Thanks! Your help is very appreciated!
Old Aug 6, 2002 | 09:47 PM
94touring's Avatar
With the apexi fmic, and others you have to relocate your condensor. With a intercooler kit you have all the approriate brackets and so fourth to make the move easy. I'm sure it can be done without a fmic, it would just take some time to figure out and a few trips to the hardware store. Anyways, unfortunatly putting the condensor on the bottom of the car parallel with the ground doesn't allow much air flow and makes the ac work poorly. However you can easily fit a fan on the condenser without worrying about it getting ripped off over speed bumps or whatever. All you have to do is splice into the existing fan wires to make the fan work. In my case I have my radiator fans working through the haltach, they come on at 180 and shut off at 175, very cool feature. So since I still have the stock fan connectors available, I simply took my stock radiator fan connector, cut one off and spliced it into a fan I bought at auto-zone. So now anytime I want ac, I just hit the button like normal and the fan comes on and i'm cool and happy.
Old Aug 6, 2002 | 09:50 PM
94touring's Avatar
Oh yeah, I used both stock connectors and spliced into a single 12" fan. It makes it "zing" its spinning so fast.
Old Aug 6, 2002 | 09:52 PM
DamonB's Avatar
You'll gain as much horsepower from removing the a/c as you will from just setting the switch to "off".
Old Aug 7, 2002 | 01:04 AM
From: Minnesota, now in FL and I dont think I'm goin back
I live in MN right now and took out my condeser so I could get better flow to the radiator. Now I'm moving to FL in 10 days, I hope I can bare the heat. just have to have the windows down lots.
Mike
Old Aug 7, 2002 | 01:15 AM
spooledUP7's Avatar
There and back again
If you want to lose 50 or so horsepower just push that little AC button.
Old Aug 7, 2002 | 08:04 AM
evot23's Avatar
Classy
94touring
Was it necessary to remove the refigerant to move things around or did everything bend fine? If its too much hassle, I may just remove it all.
Thanks again!
Old Aug 7, 2002 | 11:30 AM
JM1FD's Avatar
The A/C uses about 10hp when cycling....not that much, really.
Old Aug 7, 2002 | 11:32 AM
94touring's Avatar
94touring
Thanks again!
You will have to bend everything around, we didn't have any problems. You just need to be carefull when bending.
Old Aug 7, 2002 | 12:35 PM
CrispyRX7's Avatar
Polishing Fiend
evot23,
Yeah I did this too - lowered the condensor flat that is;
Perhpas the following will help you visualize what I did.
http://www.negative-camber.org/crispyrx7/cwric3.htm
Regards,
Crispy
Old Apr 21, 2004 | 08:01 AM
judgekim's Avatar
From what I have read it appears to be easier to add an additional fan than move the condenser. Is this also more effective in keeping cool?
Old Apr 21, 2004 | 12:12 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
My mom is too. Funny, I always thought she was full of ****!!
Old Apr 21, 2004 | 12:20 PM
fastcarfreak's Avatar
3rd motors a charm I hope
I removed mine cuz i dont use it anyways. It saved some weight too. The FD is actually set up to have the perfect airflow through the **** pit with the driver side window down and the sun roof cracked open. Its perfect and you dont lose power from running the AC. Try it if you dont believe me and drive at ruffly 30 or 40 miles an hour. I actually believe this was stated in one fo the car magazines about 10 or 11 years ago.
Old Apr 21, 2004 | 02:29 PM
moehler's Avatar
I never even use mine... I feel like I'm hurting my FD. I might as well take it out. It gets hot as ****, though .
