How d I adjust idle RPM?
Old Mar 11, 2002 | 07:48 PM
Zoomspeed's Avatar
how do you adjust idle? My idles is only about 500 RPM right now. What should the idle be after the car is all warmed up and has been drivin a little while?
Old Mar 11, 2002 | 08:03 PM
rynberg's Avatar
is your car otherwise in tip top condition? What is your vacuum at idle?
Old Mar 11, 2002 | 09:16 PM
Zoomspeed's Avatar
yup, my car runs great. I'm getting 12-15 inHG (depending on the atmospheric conditions) @ 500 RPM.
Old Mar 11, 2002 | 10:16 PM
Trexthe3rd's Avatar
The idle should be at 750-800 rpm. There is a small set screw that can change your idle, just follow your throttle cable and you'll see it.
Old Mar 11, 2002 | 10:43 PM
luneytune's Avatar
Use the procedure in the manual page F-16 to F17. The primary adjusting screw is below the intake elbow. The one near the throttle cable is used only after the lower screw as per the manual.
DerpyToast
14
Nov 23, 2024 05:19 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
gabescanlon
Sep 5, 2015 12:09 AM
rx7shirley
Sep 2, 2015 02:11 PM
