Looking for stainless steel gasket material
Black Sunshine FC
Does anyone know if there is a shop or parts store anywhere in Northern California that sells the multi-layered stainless steel gasket material (like Racing Beat uses for its gaskets)? Or somewhere else we could order some?
We're just looking for a small piece (~8 inches square) that can be used to create a gasket between Tony's turbo and his exhaust manifold. Everything other than the stainless steel material keeps blowing out.
Thanks for all info...
I'm not sure about finding the material, but i'm pretty sure you can get the part from Atkins. You can also try Malloy Mazda. You'll have to do a search on the forum for their info but Zach says if you mention you're from this forum they will give you a ten to twenty percent discount. Hope this helps. Good luck Liz!
