B&M shifter doesn't fit
Old Dec 24, 2006 | 08:52 AM
mmaluso's Avatar
I just did a swap from auto-manual and my B&M shifter fits very badly. There is no way I can get to the front two bolts on (Im even using hex wrench cap screws) even if I use a prybar to move the transmission. I did the test drive with only the two back bolts tightened but I obviously dont want to drive around like that.
Is this a normal thing for aftermarket shifters? I really dont want to gring away at the trans tunnel but I guess I'm going to have to.
Old Dec 24, 2006 | 09:08 AM
Mahjik's Avatar
Mr. Links
Arrow
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/rubbing-grinding-noise-found-how-do-i-fix-302692/
Old Dec 24, 2006 | 10:37 AM
mmaluso's Avatar
Hmm that seems like its talking about side to side adjustment. Im pretty sure i have good clearance on each side and the shifter housing is centered in the trans tunnel. My problem is that it is just slightly too far forward. Just enough that the bolts what to go in diagonal so i cant get the threads started.
It seems to me that the transmission wouldn't have any front/back adjustment because of the ppf. Am I wrong?
Old Dec 24, 2006 | 11:57 AM
Mahjik's Avatar
Mr. Links
It should be a little under the tranny opening, but not far enough that you can't get something like a open ended wrench on it. You probably won't be able to get a socket on it. Those flexible ratching wrenches usually work great for these types of areas.
Old Dec 24, 2006 | 01:49 PM
Sprockett's Avatar
Former Rotorhead
you sure you don't have it in backwards? I've done 2 B&M shifters in FDs and neither gave me any trouble.
Old Dec 24, 2006 | 02:07 PM
GoRacer's Avatar
Speed Mach Go Go Go
I had the same problem with my replica. Some people said realigning the trans fixed the problem. I ended up cutting a notch in the corner to allow the hex bolt to go strait down. I'm actually bummed I did that even though it's never seen but I wasn't able to do it any other way. Maybe you can try loosenin the PPF bolts and pry the trans over temporarily enough to get the bolt in and tightened?
Old Dec 24, 2006 | 02:40 PM
RE-Amemiya's Avatar
Not the company
No problem's with the B&M i had in my FD, hope you get it fixed/figured out.
Old Dec 24, 2006 | 05:10 PM
Chadwick's Avatar
Mr Sparkles
My guess is that your engine is leaning to far foward, loosen up the bolts on the PPF (at the transmission) and pull down on the end of the transmission, then tighten them back up. The PPF has a little play in the bolt holes and you should be able to get the clearance you need to insert the screws.
Old Dec 24, 2006 | 05:42 PM
JeffShoots's Avatar
I had the same problem with the top right bolt. Just keep working it with a flexible wrench.
fidelity101
13
Aug 31, 2015 07:47 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
