Bad Alternator?
Old Dec 22, 2006 | 07:44 AM
DrunkenBowler's Avatar
Bad Alternator?
Once the car is started, it wants to stall out. Lights are flickering when it gets down around 1000 rpm. When I hit the brakes, the lights on the console dim. In order for me to keep the car moving is to hit the gas. I think my alternator is going out. What do you guys think?
Old Dec 22, 2006 | 08:21 AM
surfmon's Avatar
take it off, get it tested
Old Dec 22, 2006 | 08:27 AM
DaveW's Avatar
Racecar - Formula 2000
Check out your battery, also. Of course, a bad alternator would run the battery down.
Dave
Old Dec 22, 2006 | 08:44 AM
It's a brand new battery. I had the alternator tested last night, and it doesn't keep the voltage at 14. It keeps it around 13.7-13.8, somewhere around there. The guy who tested it said it was alright.
I may have to adjust the both idle screws, ISC, TPS, and check that wax rod thing, but I'm sure this alternator is on it's way out.
Old Dec 24, 2006 | 07:45 PM
Monsterbox's Avatar
Mazzei Formula
hmm...
i'm having a similar problem
sometimes when i crank the car starts up VERY fast runs for about 2 seconds like normal then the idle dips WAY low and recovers...car runs fine for rest of the time period
or..starts up dips WAY low until it dies....does it again...and again....unless i hold the gas down a little bit for about 3 secs for it to "CATCH"
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
